to pass smog in California i need an working EGR valve for my 1979 1500 Spitfire. Seems the PO put a drop of weld into the valve cavity! (to seal it?) two questions: first, is it possible to simply drill out the weld and therefore make the valve work again? (the rubber part works fine but the stem looks like it was "cut off" was there also another piece on the end here?).
Second if i can't do the above where can i get one? can anyone help? thanks guys.
