Where can I find #4 cup washer ?
ekamm
Other than the .50 cent ones from the parts suppliers where can I find a #4 cup shaped washer that is used on the interior on paneling etc. Victoria British has it for .45 cents or so but I'm sure that you can get 100 for a few dollars. I found the screws 100 for $6.
Gliderman8
You might try McMaster Carr. Click here for the cup washers.
I hope this helps.
Geo Hahn
I have certainly obtained cup washers at The Home Depot -- never looked for the small ones you need so can;t say for sure theirs are that small -- but they had them in the sizes I needed. Alternately, an Ace Hardware usually carries a selection of auto trim items in the section with all the little drawers.
Were the screws you obtained slotted or phillips? At least one of the TR suppliers was sending phillips when you ordered these.
ekamm
ekamm
Philips and I know that that's not original. I'm in no means in the complete and perfect resto category just trying to keep the interior from falling a part and make it look a little better.
Adrio
I got mine in stainless from a marine supply store
ekamm
ekamm
Mcmaster-carr didn't have the exact same washer but did have a countersunk washer in a #4 I may just have to be happy with that. These aftermarket british places seem to want to make their fortune on a tiny washer. The ones that I looked at were $2.65 for 100.
trrdster2000 GT6 Where to find the right tire? Triumph 8
zedvictor1 Where can I find the supporting vendors? FORUM Navigation Questions 1
R TR4/4A Where to find the chrome switch bezels? Triumph 6
HealeyDave Instrument gauge numbers by year - where to find Austin Healey 2
R Where to find a 55 100-4 Austin Healey 2
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
D TR2/3/3A Where can I find steering box bearings? Triumph 2
I How do I find where battery is being drained from? Spridgets 17
T T-Series Where to find strip for MG TF sidecurtain? MG 4
R Carb help, where to find it? Spridgets 4
S Need to know where to find info MG 1
D Where to find springs MG 8
G Where can I find the chrome "MG" air filters? Spridgets 4
sparkydave Where to find an inexpensive dial gauge Restoration & Tools 20
R Where To Find Used Parts Triumph 17
C Where to find frames? Triumph 7
N Where can I find info on MG Midget engine numbers MG 0
N Where can I find info on MG Midget engine numbers Spridgets 6
germanmichel Where I can find a detailed frame Drawing ? Austin Healey 5
eejay56 Spitfire Where can I find a Spitfire 1500 shift handle Triumph 3
PATR8 Wedge Where does one find a Rimmer Aley Bar for TR8 Triumph 13
L Where to find BJ8 Cam Spec's? Austin Healey 3
PAUL161 Where to find, Concourse / Point car spec. sheets? MG 2
G TR2/3/3A Where can I find a complete TR3 engine parts book? Triumph 3
t8nwa where do i find a '80 softtop frame? Triumph 3
miranda Where to find the car number on a 100-6? Austin Healey 14
M Where to find "amber" fog lights? MG 2
AUSMHLY Where do I find the numbers on my car? Austin Healey 1
V Where to find an OEM hardtop? Triumph 2
L Where do you find "The Good Parts"? Austin Healey 12
svtmikey GT6 GT6 Paint - CODE 34....where can I find it? Triumph 15
R Where do I find? Spridgets 11
H Where can i find it? Triumph 3
S Where to find speaker grilles? Triumph 5
C where to find E type race cars ? Jaguar 5
B MGA Where to Buy, What to Buy? Axle Nut MG 8
1 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 4
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
