When did you last check your steering coupling?
tdskip
If it looks like this time to suck it up and change it....
poolboy
You've read up on the tricks to installing a new one ?
I hadn't and swore for an hour or so that I was sent the wrong part.
Stinger
I just replaced both on my TR4A. They almost fell apart when I removed them! The lower one went on easy and the upper one had to be compressed a bit due to the steering angle. Dont forget the safety wire.
T
tdskip
Hi Ken, I did actually and rebushed the column while I was at it. Pretty straight forward but the final step of compressing the darn thing, even with Bob's excellent write up, was still a pain in the neck.
Haven't actually driver her yet but as soon as the distributor arrives back from Jeff she'll get a work out (I hope).
DNK
Can anyone explain to me WHY it has to be a pain in the ... to put on?
poolboy
I'm sure that I've done this in the distant past on another car, but I don't have any recollection of it being the struggle that it was on the TR6
Same goes for the fan belt, and the whole oil cannister ordeal.
TR3driver
Great Pumpkin - R.I.P
Just a WAG, but I think they wanted it compressed to be stronger. The bonded rubber isn't nearly as strong under tension as compression, so compressing it as you install it makes it less likely to pull apart in the future.
BobbyD
angelfj said:
"Bob's excellent write up" where might I find this? thanks
LOL.......Welcome to Bob's! Here's the write up and the trick to getting a new coupler on. As was noted, the coupler needs to be compressed to get all the holes to line up. Different guys have done it different ways but this is the way I went based on a friend's suggestion. BTW...if you've never replaced this coupler, chances are it's cracked and impacting steering response. Unfortunately the only way you'll ever find out is to remove it.
And don't forget the little ground strap that goes between the upper & lower shaft.
T
tdskip
With the engine in the right place the fan belt is a breeze, when the engine is too far, well that is a different story in my experience....
poolboy
Tom, I agree that moving the engine & tranny back might solve the problem, BUT, in the Haynes Manual in Chapter 2 / Cooling System, Section 13/ Fan Belt-removal and replacement, it instructs to remove the cross tube. Makes me think that it is in the right place. I think that by moving the engine and tranny back, you might be reducing some of the forward and aft potential movement of the drive shaft splines.
I guess you pays your money and takes your chances. What you think ?
T
tdskip
I removed the crossbar the first time around and found that it was a major paint in the butt, might have just been my car (this was on the 1971 that was/is a mess).
Pushing the engine back slightly made it a piece of cake.
swift6
And why once it is in place, would the driveshaft need much of any foreward and aft movement? The engine and trans should not be sliding fore and aft and since the diff is mounted solid it shouldn't need to move much either.
poolboy
I guess that there's some flexibility in the engine, tranny and differential due to torque, rough roads, I don't know; why have the splined joint at all if everything is so rigidly in place ?.... Or 2 Universal joints for that matter.
TR3driver
Some Triumphs don't. It's my suspicion that they kept the sliding joint mostly so they didn't have to redesign the driveshaft (which I believe is common with the earlier TRs). But since the whole car does flex somewhat, especially with spirited driving, it's probably best to have the spline to relieve the force instead of having the possibility of side-loading the ball bearings in the gearbox/overdrive.
poolboy
I'm not a tranny or differential specialist either, but seems to me that w/o a splined joint, the pinion and tranny shaft could transmit a lot of force once their end play float was used up.
DNK
I had a 73 Capri V6 that when I removed the rubber coupler and replaced it with a solid coupler the steering response was amazing. That and the good bushings made it steer like a different car. Why not for our car"?
Note: Tom, I wasn't questioning why it was hard to put on but why it was designed like that.
poolboy
BobbyD said:
Don..... I think TRF sells, or sold, a solid coupling to replace the rubber one. Nice to see this thread get back "on topic"..... sort of.... :yesnod:
Yeah, I hate it when people change the subject,,,,,oh yeah that was me ! pb:hammer:
JPSmit Hyundai Stellar - when last did you see one? Other Cars 6
JPSmit When did you last see one? Spotted 57
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
Y MGB How did become such a mess up???? MG 2
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
V MGB Mystery fastener from '66. Did I miss something? MG 6
mezy Heres one i did. Other Cars 9
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
jlaird MGB Don't post like I did 10 years ago. MG 7
AngliaGT MGB What Did You Do on Your MGB Today? MG 6
JPSmit Honey, did you hear that clunk? Other British Cars 0
B TR4/4A What did I do wrong? Triumph 19
Elva164 Finally did another onboard video! Racing 4
Jim_Gruber When did Mini’s get so expensive Spridgets 20
J TR4/4A Did my own carpet Triumph 16
Jim_Gruber So what did I do wrong here with Bugsy. Spridgets 2
Jim_Gruber Did my clutch just bleed itself? Spridgets 11
warwick-steve Where did the smell go? Austin Healey 11
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
kennypinkerton MGB Things I remember that I did to my MGB... MG 4
TomMull TR2/3/3A Did sombody just get lucky? Triumph 4
PC Morgan fans - how did I miss this? Other British Cars 2
longbridgehealey When did you buy your first LBC, and what was it? Spridgets 46
H 1925 Rolls Phantom I "round door Rolls" in Petersen collection: what did it sell for? Other British Cars 5
H Joan Baez flat floor '61 roadster, what did the Feds sell it for at auction? Jaguar 0
nicko Did you know....... Austin Healey 15
K General Tech Why did MGB's come with oil coolers but Triumph's didn't? Triumph 17
R Where did it go? A who-done-it mystery! Austin Healey 18
Rut TR4/4A I did it again... Triumph 27
PC didn't spot a 911 or a Javelin but did see a station wagon Spotted 1
T TR4/4A Access to a professional sandblasting set up - why the heck did I wait so long... Triumph 4
Editor_Reid FYI re "What Did You Do On Your Austin Healey Today?" Austin Healey 0
CessnaTPA What Did You Do On Your Austin Healey Today? Austin Healey 98
2billydavies TR2/3/3A just removed the pistons/sleeves... can't believe she ran as well as she did! Triumph 6
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
H Michelotti one off body on an E-type? What year chassis and what shop did the work? Jaguar 0
C The "Lightweight" Jaguar E-Type.....why did they only make six?? Jaguar 2
D Challenger 2.5 did 419 one way at the flats today. Racing 2
Gliderman8 TR6 Did one of you guys lose this? Triumph 10
P General TR What vehicle did this windscreen come from? Triumph 2
tinman58 TR5/TR250 Did I screw up? Triumph 4
glemon General TR What Did You Do to Your Triumph Today? Triumph 119
Moseso TR2/3/3A PeterK, or others -- How did you mount your BMW fan on the TRactor motor? Triumph 3
trrdster2000 Off Topic What did you expect? Triumph 6
58Custom General MG What wheels did I buy? MG 8
R How long did it take to restore your car? Austin Healey 18
Rut How did you come to own a Bugeye? Spridgets 17
69sprite New trailer - Did I miss the mark? Spridgets 8
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
