TR2/3/3A When assembling a release bearing to the sleeve?
karls59tr
Bronze
How far should the bearing be pushed on to the sleeve? I have a sleeve and release bearing I'm looking at from a TR4 in my hand and when looking at it from the release bearing side it protrudes from the sleeve about a 1/2".
When I installed the release bearing on the sleeve of my Tr3 when I had the gearbox out I'm thinking I may have pressed the bearing on too far and that's why I'm having clutch issues now???
How far ideally should the bearing be pushed on and what method could I use if I had to relocate it?
CJD
I'm drawing a blank right now about the design of the sleeve, and whether or not there was a ridge on it to locate the bearing. But, if there is no locating ridge on the sleeve to stop the bearing, I have always pressed it right up to the groove. The best way to describe is is that if I tried to press it any farther, I'd break something. Sorry, I've looked through all my pics, but can't find any of the throw out bearing assembly...
K
karls59tr
Bronze
No worries. Thanks for the info. I believe I've resolved the issue I had with my clutch slave adjustment. I had to combine the TR6 and Tr3 methods of mounting the slave to get the adjustment right. Seems to be working now. Maybe someone else will chime in on the release bearing question. :smile:
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
R TR2/3/3A Re-assembling 1954 TR-2 Engine Triumph 25
R TR4/4A Assembling the interior - dash support and radio plate screw holes don't match up Triumph 4
J Tips on Re-Assembling Lenses/Gaskets? Austin Healey 5
BN6_2197 Question on assembling BN6 hood Austin Healey 6
drooartz Assembling rear hubs -- do I have this right? Spridgets 5
Z assembling doors Spridgets 3
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
D General MG Kimber Fest Press Release MG 1
Bayless Help please installing bonnet release cable Spridgets 8
R TR6 Stronger hood release? Triumph 4
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
K Missing spring clutch release lever Other British Classifieds 1
steveg TR6 Hood release pictures needed Triumph 22
S Wedge tr7/8 quick release steering wheel Triumph 0
B TR6 TR6 Hood Release Cable Triumph 7
C Bonnet Latch/Release Adjustment Austin Healey 3
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
John_Mc TR6 Front brakes won't release Triumph 20
B Clutch Release Bearing Austin Healey 2
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
Michael Oritt Oil release valve plunger stuck Austin Healey 9
W General Tech Clutch Release Question Triumph 6
R TR6 bronze sleeve for release bearing Triumph 1
K Austin A95 bonnet release lever? Other British Cars 0
B MGA Clutch release bearing MG 4
Bob_Spidell Release Bearing Quality Austin Healey 8
6 Bonnet Release Spridgets 3
T TR4/4A Release Bearing Sleeve Triumph 0
S TR2/3/3A TR-3 Hood Dzus Will Not Release Triumph 17
C Clutch Release Bearing Austin Healey 5
T Clutch release bearing question Spridgets 10
Xte New clutch release bearing completely detroyed ... Austin Healey 4
K TR2/3/3A Clutch Release Bearing Triumph 4
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
B bj8 bonnet release broke Austin Healey 11
Gerard Release bearing return spring for 210 gearbox Spridgets 3
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
Healey Nut BJ8 Release bearing Austin Healey 14
I TR6 Bonnet release cable Triumph 3
S TR6 Suggestions: cylinder head won't release from block Triumph 10
K TR2/3/3A What's the easiest way to remove the clutch release bearing from the bronze sleeve? Triumph 7
RJS Emergency hood/bonnet release Triumph 22
K TR4/4A TR4A Clutch Release bearing Triumph 6
W E type bonnet release Jaguar 0
J Sprite Bonnet release cable routing Spridgets 2
K TR2/3/3A TR3Clutch Release Bearing Triumph 2
O sprite release bearing Spridgets 5
