Trevor Jessie
Arggh. I have rebuilt several spridget front suspensions. When everything goes as it should it is a relaxing and "fun" job. For some reason the latest one is fighting me. I want go into all the problems that I have had to overcome, but I am a little stumped on this last issue (I hope it is the last issue). Here it goes:
The caster angle on the kingpin is placing it too close to the shock such that when the trunnion is installed it flexes the pin and causes binding of the swivel axle.
Here is what I've checked: king pin is correct, all bushings are fully seating, shock arm is not bent, no indication of accident damage, the a-arm seems straight and true.
I moved the other a-arm over, with its kingpin, and it didn't work either. I built up the tab slot for the inner A-arm fulcrum pin the raise the pivot of the front of the A-arm. That helped, but I can't take it any higher. None of the holes look enlongated from wear.
Do I shave the shoulder on the trunnion bushings? Mill the edge of the trunnion and the side of the shock arm?
I've had a few that were snug, but never one like this.
What about lowering half of the spring pan?
If I use a long pry bar and twist the a-arm to correct the caster the swivel axle turns freely... So I do not think it is "off" by much.
Any thoughts?
... I'll edit this and try to clarify things tomorrow after I've had some coffee, but right now there is another beer calling my name.
Any thoughts?
