Wheel Dollie Recommendation?
AngliaGT
Need to fit three cars into a two car garage,but it has those stupid
support posts right in the middle,so it's too hard to make the hard corner.
Is there a reasonably priced,well made set? I used a Harbor Freight set
when I delivered a TD for a guy.Had to move it about 30 feet.A single wheel
broke off of two of the dollies,so I would never even consider buying from HF.
I bought mine from Princess Auto (Canada's Harbor Freight) and am quite happy. No idea about source but I love the Hydraulic ones> I just have two and they work great!
I have a set that looks very similar to those and they are work really well. I find that I use them all the time. Don't just buy the cheapest ones available. Get some good ones that don't require a thousand pumps to lift the car. If I can get to my storage garage, I will check out the brand on mine and post it here.
How heavy of a car / how often do you want to move it? Are you OK with jacking it up onto the dollies each time you need to move the car(s)? I've had good luck with furniture dollies for a lightweight British car - but infrequent moves and required a jack to take the car down. (An upgrade would be to buy better casters, which would still (likely) be cheaper than dedicated metal car dollies like what JP has pictured.)
