I'm trying to re-fit the wheel cylinders on my 64 tr-4. I'm using the moss wheel cylinder fitting kit and having a hard time getting third clip in place without it bending. Anybody have a trick to getting these buggers in place?
In the picture you will see three of the locking plate parts labeled A, B, C. The trick is to install A and B first, then drive in C in between the two installed parts. So that little clip labeled B is not the last piece to go in. No bending, once you get the hang of it you'll find it easy I think.
