I need some experienced help from you guys. I just rebuilt the front suspension on my 74 B and have spent a lot of time to do it right. New shocks, springs and now wheel bearings. I spent 4 hours yesterday installng the wheel bearings. I read what I had in the Bentley and got some information here from some old posts.
The left side went rather well...I started with 4 shims and had a little too much play, so I removed the thinest shim and retorqued the nut. Now 40 ft lbs takes the nut past the hole for the cotter pin and 70 ft lbs does not reach the next hole...should I back off to 30 lbs or tighen the nut to the next hole??? How tight is too tight???
The right side has taken more time. I started with 3 shims (that I removed and cleaned from before) and it bound when finger tightened. I have removed the entire assemble and rechecked everything, added another 3 shims and it still binds, but does not wobble. How many shims can be added here without causing trouble???
Any and all suggestions are appreciated.
Bruce
Bruce
