RAC68
Hi All.
A number of years back I followed prevailing directions and created a wire wheel spin balancing adapter. The instructions directed that the flange of a rear hub be cut down with a hole placed in the center of a companion spinner. It was recommended that the hub be mounted onto the spin balancer shaft using 2 cones (1 in the center of the hub and 1 through the hole in the spinner). On the few occasions I was able to use the adapter, I found it much better than not using it. However, I found it difficult to find a tire service with a machine that had a long enough shaft or an appropriate selection of cones to mount the adapter.
How many have used a hub adapter for wire wheel balancing? How has the adapter been mounted on the spin balancer? What type or brand name of spin balancer have you found would accommodate the adapter? Are there any suggestions that would helped the balancing process? How satisfied were the balancing results?
Thanks,
Ray (64BJ8P1)
Thanks,
Ray (64BJ8P1)
