Justin Bowen
I had the motor running. Every time I hit the starter it would crank and run.. idled rough usually, wouldn't stay running for more than 30 seconds unless I gave it gas. I was happy with that as a starting point, then this....
about a week ago I was running the motor to test a few things and it died and wouldn't start back up. I figured I ran it out of gas, which is very possible since I only put about a gallon in the tank.
Now, a week later, I add 2 gallons and the thing just won't start. I pulled the fuel line at the carb and it does move some fuel, but in spurts, not a smooth flow. I seem to recall it was like this before though, when it ran.
Any ideas? Could there be air in the line? If so, how do I fix that?
Thanks, you guys have been a big help so far...
Justin
Justin
