jclay
Hey, Odd,
The clutch isn't so bad if you drop the rear crossmember. I used a floor jack to raise and lower the back of the trans as necessary to access all of the bolts. Now, get the trans off the engine, that takes some work. Hum? Putting the trans back in isn't a picnic either.
The one I dislike the most is the lower steering bush. But I did twist one of the tie rod arms once. That was a bear to get off the rack!
jclay
jclay
