I'd like to fix and/or replace my grille insert which contain the vertical slats. Before I go ahead and rip my TD apart, I'd like some seasoned suggestions on how to approach the task.
I've got one loose grile slat. I could do a short-cut, like fix it in place with JB Weld, but I'd rather replace the whole section, if the replacement from Moss is indeed worth fitting. I'm also going to change the color, which should probably steer things toward removal and replacement.
Thank you very much in advance,
Matt
Matt
