Mwalsh
I have been borrowing 26mm and 32mm wrenches from the company I work for on the rare occasion that I've needed to make adjustments to the adjustable suspension (hi-los) on one of my Minis.
The setup is basically you jack the car up to take the weight off the suspension then undo a jam nut (32mm) on a large bolt (26mm) and turn the bolt in to lower or out to raise.
I've long thought that I should own my own, but don't want expensive ones just for that very rare occurrence.
My longtime favorite for cheap hand tools, Agri Supply Company, offers several cheap metric and SAE sets, starting at $14.95 for a 14-peice set. However the metric sets, while they both include a 32mm wrench, skip over from 24mm to 27mm. Individual wrenches are available but are, as seems to be commonplace, expensive compared to the sets.
So, my question is...should I buy a metric set and have the 27mm wrench be just a bit too big or buy a SAE set and use the 1-1/4" and 1" sizes with just a hair taken out the 1" size with a dremel (26mm is 1.023")?
Hi Guest!
