Re: what tires for a 100 BN2? 185/HR15 or 185/70HR
To add a pic, this works for me if the pic is on your hard disk. I believe the pic must be in jpg format & less than 250K in size. png format files may also be accepted though I haven't tried it.
1- At the bottom of the message box "switch to Full Screen Reply"
2- At the bottom, click on "File Manager"
3- Click on "Browse". The files on your hard disk should be displayed.
4- Scroll to the pic you wish to attach & select it.
5- Click on "Open"
6- The file manager should now show the title of your pic below the "File" box.
7- Click on "Add File"
8- The named pic will now be shown above the box.
9- Select more pic up to five, in the same way, or click on "Done Adding Files"
10- "File Manager", below the box, will now show a "File Total"
11- Click on "Submit"
You are done!
If your pic is not less than 250K you will need to resize it & or decrease the resolution to 72 dpi. There are lots of pic resizing & file type changing programs available.
If the pic is under some, minimum size, don't know the size, it will display directly in line. There are ways to make larger sizes display in line also, but I don't bother with it.
Good luck,
