What the trick to the steering column bushes?
jackag91
I have been struggling with this all day and have about given up.
How do you get the old bushes out of your steering column on a TR6?
I am guessing these there is a trick to it but I can't figure it out.
Or does anyone know of a place that rebuilds these?
sail
I did my 4's using a threaded rod long enough to go clear through the tube. For the first bush pull it out with an expander slid through the center. A big washer on the other end with a turning nut. Be careful the expander does not catch on the soft tube. For the second use a washer to avoid that problem. And before you start cut the norts off the bush where they stick out the holes in the tube. The new ones I pulled in just catching the bush edge with a washer small enough to come back thru the hole.
BobbyD
Jack....rather then remove the old bushing just get Art Lipp's Delrin bushings that get pressed on over the old ones. You can see how easy it is to do here. It's $25 for the kit or you can send Art your old column and he'll rebuild the whole thing for you. But putting these bushings in is so simple that you'll be pleasantly surprised.
DNK
New there was an easier way. Did mine before I found this time wasting board :laugh:
J
jackag91
It looks like mine (73) has a steering wheel lock on the the inner column, so I can't get the inner column out until I get the bushing out.
Hey chicken! have you met egg?
I think for price, I might just send it off to Art's.
RobSelina what's the trick to getting a steering wheel off? Spridgets 36
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
Basil Neat trick for reading oil level Restoration & Tools 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
N TR2/3/3A Cheap trick Triumph 5
Graham H TR2/3/3A Randall's Trick Triumph 10
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
S Ramps. What's the trick? Spridgets 23
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
Got_All_4 TR5/TR250 Rope trick on a broke valve spring Triumph 8
S Trick or Treating Spridgets 5
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
S So, what's the trick... Spridgets 17
T TR6 tr6 water pump trick? Triumph 4
H Trick needed - for body curve Austin Healey 12
Henson80MGB Trick to remove rubber hose to Slave Cylinder? MG 19
C Trick Midget Mk1 Racecar Spridgets 15
P help: trick to snap and unsnap soft top ? Triumph 11
glemon 11/64s drill bit tranny mounting trick Triumph 10
M Weber Carb trick Spridgets 1
BOBBYR Trick question . See what you think. Austin Healey 10
W A neat trick Spridgets 1
Jim_Gruber Rinstalling Beehive Lamps on BE what is the trick Spridgets 7
RickB Any trick to replacing shackle bushings? Spridgets 5
jlaird Very slick trick Spridgets 3
zimmy my new clutch bleeding trick Spridgets 10
Jim_Gruber Removing Aluminum Channel on top of door - Trick? Spridgets 5
W New or another ebay fraud trick Triumph 8
jlaird For my next trick Spridgets 5
J So what is t he trick for getting the ujoints out? Triumph 3
J Any trick to getting the bump stops off Triumph 14
P Nut and wire Trick Triumph 9
E TR6 TR6 Front Suspension... Is there a trick? Triumph 8
aeronca65t MGB Semi-trick MGB MG 7
G Out with the rubber-hose-to-the-ear trick..... Triumph 10
tomshobby Kind of a neat trick. Triumph 4
aeronca65t Trick Pontiac GTO Other Cars 3
A Spitfire Trick to remove 78 Spit carb? Triumph 4
G Neat trick Triumph 5
Alan_Myers TR2/3/3A TR2/3/4 cooling trick? Triumph 1
Z Rope trick works! Triumph 10
J Exhaust Valve - dollar bill trick! MG 20
Steve Secret door trick MG 1
Basil Rope Trick Triumph 2
S Sticky Steering Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
