Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
I did my 4's using a threaded rod long enough to go clear through the tube. For the first bush pull it out with an expander slid through the center. A big washer on the other end with a turning nut. Be careful the expander does not catch on the soft tube. For the second use a washer to avoid that problem. And before you start cut the norts off the bush where they stick out the holes in the tube. The new ones I pulled in just catching the bush edge with a washer small enough to come back thru the hole.
Jack....rather then remove the old bushing just get Art Lipp's Delrin bushings that get pressed on over the old ones. You can see how easy it is to do here. It's $25 for the kit or you can send Art your old column and he'll rebuild the whole thing for you. But putting these bushings in is so simple that you'll be pleasantly surprised.
Jack.......Art does real nice work but I don't know if rebuilds the column with stock bushings, his bushings or both.......so you might want to ask just to be sure.
I sent my column to Art and he did a great job and not only were the bushings replaced the entire column was restored and refinished. He did a great service at a reasonable price.
