2 different companies made the needles. The numbered are/were made in the US, the lettered SU I worked for the US guy making SU parts, back in the early 70s. I've attached the conversion file for some folks. If anyone needs the cross reference, I have it. Peter
How come the adjusting nut with the spring above it turns the jet bearing sleeve? What have I done wrong, with out the spring all is fine nut is smooth turning.
Old brain cells need diagrams to improve connections.
[/ QUOTE ]
I read somewhere that you can drink a few pints to kill off the slow brain cells and then you will feel smarter. This early in the day, I'd suggest Boddington's.
