Alan_Myers
Hi all,
What size valves are you using in four cylinder TRs?
I've got on hand a set of 1.65" intake/1.42" exhaust, but am thinking these are too large. I know for certain they won't fit, along with valve seat inserts (for unleaded fuel) on the exhaust side. (There's just not a lot of room to play with valve sizes in the 4-cyl. head's squish area.)
Stock sizes are 1.56"/1.30" (39.5mm/33mm).
In oversize, I've found:
- Inlet:
1.61" (40.89mm)
1.65" (41.95mm)
1.66" (42.18mm)
1.67" (42.42mm)
- Exhaust:
1.40" (35.56mm)
1.42" (36.07mm)
Car needs to be "streetable", but is getting "improved" in a lot of little ways. It will have a 182 degree duration/high lift cam. I'm still undecided whether to use 87mm or 89mm pistons/liners (the former, which I have on hand, will qualify for most production class autocross, while the latter usually bumps the car into modified classes). Carburetion is a pair of Weber 40DCOE, most likely with 34mm primaries. Head is skimmed to give about 10:1 compression ratio and has been ported and gas flowed (but will probably still get some more improvements).
All the above O/S valves are stainless steel/improved gas flow design. Of course, a larger size valve can always be custom reduced and reshaped into a smaller size.
Seems to me the stock TR exhaust valve size, in particular, is a little skimpy. The rule of thumb I've always heard is that exhaust valves should be at least 85% of the size of intake valves, to allow for proper scavanging. TR stock exhaust valves are 83.333% of the stock intake valves.
Decisions! Decisions!
Anyone have any magic words of wisdom to share or complicated formulas to apply?
- Inlet:
1.61" (40.89mm)
1.65" (41.95mm)
1.66" (42.18mm)
1.67" (42.42mm)
- Exhaust:
1.40" (35.56mm)
1.42" (36.07mm)
Hi Guest!
