Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
I had my cylinder head cleaned, and while it is off, I thought it would be a good idea to run a tap through the spark plug threads. Can someone tell me what size tap to use?
If you have a set of taps and dies;
find which die fits the threads on your plugs
and then use the matching tap for your plug holes.
I would suggest caution since the plug threads
have probably had plugs in and out a few hundred
times over the past 40 years. You don't want to
go removing more metal from the threads if you
can avoid it.
Just my 2 pence worth and I'm the tap/die everything
guy. I would leave well enough alone.
Kevin, Sears or almost any automotive supplier sells a special tap specifically for chasing spark plug threads. I strongly recommend using it rather than an ordinary hand tap, as it greatly reduces the chances of damaging your head. https://www.sjdiscounttools.com/kdt3379.html
The threads are unusual anyway (specifically for spark plugs) and not usually found in sets. Metric, M14 x 1.25 as I recall (but don't quote me).
