red57
Andy,
I would be very careful about removing the 'eyebrow' - that is the "squish" area and it helps create a swirl in the incoming charge, helping to insure a complete mix and burn. Second, if you do remove the squish area you may well have to have raised dome pistons to get a reasonable compression ratio. I have seen serious Healey race motors with head modifications like you are contemplating but they have raised top pistons and are probably running 12 or 13:1 (maybe more). If you remove the eyebrow and still have flat top pistons, I'm not sure you could skim the head enough to get the compression ratio where you want it. Point I'm getting at is that if you make that radical a change, there may be some downside.
I run about 9.5:1 and still have the eyebrow, have unshrouded the valves and skimmed over .060 off the head and still have 9.5:1. My chambers are about 48cc, and my guess is you would need to be arouond that, 48-50cc, with flat top pistons to be in the ballpark. I think unshrouding the valves and smoothing the eyebrow (rounding all edges) will help, and for sure help your air flow. I suggest you read the David Vizard book "Theory and practice of cylinder head modifications". Great info and very helpful.
Good luck,
Dave
Good luck,
Dave
