What Now, new gas tank filler neck is about 1/2-3/4" too short
Jim_Gruber
Team,
Need some thoughts. The Filler neck on my Canadian Made Gas tank is about 1/2" to 3/4" too short. It comes just flush
with the boot deck. Bolted up tight down below. and even without the filler neck gasket not sure it would make it there. So is my option.
1) Find a tank neck off of a latter Spridget, cut this tank neck and use that rubber hose from a later Spridget to connect to the tank. That would probably work but in these days of ethanol not sure how wise that would be.
2) Could try going without a gasket up top. Again absolutely minimal amount of the filler neck is up above the top of the boot.
3
) A LeMans style cap but even those need some amount of filler neck up above the top of the boot. My odds of getting to a show next Sunday just went to slim.
Mine was shorter than the stock tank, but it was long enough to go through and use the gasket. How thick is the packing between your tank and the body?
If the tank is new I would just slice the tube and weld in a section of tubing to get the length I need.
But before doing anything drastic, fit it without the grommet and see if it is long enough without the binding.
Rut
Jim,
My tank was just a little short too...not as short as yours though. Trevor has some good suggestions and if all else fails you can cut and put a hose in like the newer Spridgets.
Rut
markberry
Hmmmm. I just put one of those Canadian made tanks in my Bugeye and it fit perfectly. You're sure there's nothing bent on top of the tank that could be interfering with the boot floor?
Jim_Gruber
Jim_Gruber
Tank is new, How about the rubber sleeve used on Spridgets Post '62. Angles here are pretty **** critical. Let me go drop the tank and refit without the grommet.
SD Bugeye
My tank is a later and I cut the neck off another and used hose between them
12 years now no issues.
Desert Rat
I had the exact same problem with my replacement tank. I've seen some fit perfectly and some not. Cut the neck and use fuel approved hose from NAPA.
Jim_Gruber
Jim_Gruber
Other option is to put the old tank back in with the new Fuel Sender. The old tank was in pretty good shape but I had noticed a few rust flakes in the fuel filter. Not many but I did see 2-3 when I looked at the filter.
Joe Schlosser
Jim
Have you put the two tanks side by side ?? It would tell you if it is the install or the Tank. I just installed ( last fall) a new tank Ebay Canadian Mfg with no issues. It was a pain to fit but neck is correct length.
If it is the tank, and you do not want to weld, just extend it with a piece of fuel hose as mentioned above
Jim_Gruber
Jim_Gruber
Joe that is likely the solution I will end up with.
BlueMax
You can fix it this way...
glemon
Many cars use a rubber intermediate hose. I would just cut it and fit a couple inches of hose with a couple clamps. That is the set up on my TR250, good for nearly 50 years now, I did replace the original when I redid the car in 2010.
leecreek
And where do you think that length of gas fill pipe went? Mine was inside the tank. About 1.5-1.75 inch. Think about it........
Jim_Gruber
Jim_Gruber
Got a solution to go to a LeMans Style Cap and a piece of Rubber Hose and Clamps. And since this tank has never seen fuel not an issue with cutting. No additional 4th of July Kabooms.
So... are you go Cincy British car days? I might go. I might even drive the Bugeye if I get the pedal box/MC switched out.
Jim_Gruber
Jim_Gruber
Trevor, Show is the one in Fairfield. Won't know until the weekend. Since I need to get car operational to get down to the Muffler Shop on Sat AM. Standing between me and going are Clutch and Brake Bleeding, Resolving Gas Tank Issues, Installing Windscreen. Muffler pipe was cut just in front of rear axle in order to pull the rear end out. Pipe was welded in place from front to rear. Truly no muffler at the present time.
Jim_Gruber
Jim_Gruber
Bugsy IV will make it to the Dayton Show on August 5. Also a little nervous to drive without any time to sort out issues, like even a 10 mile Test Drive to figure out what isn't working yet.
Jim_Gruber
Jim_Gruber
Progress on Punchlist, I now have brakes. Forgot the one gotcha about converting to later backing plates, drums will likely rub rim against backing plate. Angle grinder to the rescue. Trimmed a few thousandth's off the drums and now no rubbing. Not also to self, remember to tighten brake line at Union on rear end. Hard to build pressure when line is not tightened. Once I pumped about 1/2 pint of fluid on the flood I quickly determined why I wasn't building pressure. Brakes feel great will know more in next few days. Clutch to come Thursday night. Windshield to install, gas tank solution to be found and installed. fluids into radiator and rear end, and a Muffler. Wheels are on, brakes bled ready to go romp as soon as fuel issues are resolved. ,
Jim_Gruber
Jim_Gruber
See photos of my fix on ahexp.com for fixing too short tank neck using a filler cap from a Spitfire. Too many pics there to repost over here as well.
BillD Gas Cap does fit on new tank's filler tube Spridgets 5
E Bugeye Gas Tank Filler Tube Grommet Spridgets 13
TomMull GT6 Gas Tank Outlet Triumph 0
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
B TR4/4A GAS TANK FELT Triumph 14
B Damaged threads in the gas tank Austin Healey 7
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
B TR4/4A Gas Tank color? Triumph 4
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
D What's inside the gas tank?? Spridgets 13
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
J TR2/3/3A TR3A gas tank repair Triumph 7
Michael Oritt Gas cap parts now in tank Austin Healey 17
R TR2/3/3A Installing gas tank Triumph 6
FlyingCat Spitfire Gas tank Triumph 2
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
R TR2/3/3A Pin Hole in gas tank Triumph 9
D TR2/3/3A Gas tank does not fit! Triumph 4
C MGB Found this spring in my gas tank MG 8
B Stripped Thread in Gas Tank Austin Healey 26
S TR4/4A Worm in gas tank? Triumph 7
PatGalvin TR2/3/3A TR3A Gas Cap Info and uel tank venting Triumph 4
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
AngliaGT MGB Gas Tank Removal - '67 GT MG 2
69MGC MGC New Gas Tank for my C MG 3
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
K TR2/3/3A Gas tank pipe connector? Triumph 6
S TR2/3/3A gas tank hole body work Triumph 7
maxwedge5281 gas tank and grill installation Austin Healey 29
K TR2/3/3A Gas tank to pipe connector.... Triumph 1
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
C TR2/3/3A Gas tank cover in cockpit area Triumph 3
J TR2/3/3A Gas tank fitting and ferrule Triumph 2
S TR2/3/3A with sugar in the gas tank Triumph 13
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
B TR6 76 TR6 gas separation tank - orientation? Triumph 2
C TR2/3/3A TR2 Gas Tank Triumph 6
