What? No Air Pump?
Obtong
My ‘74 MGB has no air pump! The bracket is there, but the air pump has been totally removed. Is this (or will this) be a problem?
Also, my understanding is that the air pump is related to emissions controls. If that is the case, how does it affect the timing settings? I’ve seen many specs that talk about timing for emissions and non-emissions vehicles.
Thanks for your help folks,
Obtong
chris roop
It's not a problem as long as the air rail holes have been filled in the head, and othr plumbing has been adequately dealt with. You can basically take a late engine back to pre-smog standards by removing and backfilling with appropriate parts.
Obtong
Obtong
Chris, do you know of a web site that shows how the conversion should have been done and if I should use pre-smog timing?
Obtong
Dave Russell
Yoda - R.I.P
Obtong,
Some emission devices such as EGR (exhaust gas recirculation), retarded cam timing, PCV,& retarded ingition timing, will affect the required ignition timing & fuel mixture.
The air injection has very little to do with the required timing or carb calibration.I expect that you should use the original ignition timing.
If the car runs ok now, the proper pump elimination work has probably already been done.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Obtong:
Obtong
<hr></blockquote>
kmcormick9
i actually just took my air system out today and i happened to notice this. my vacuum line ran into the air system. should i plug this or leave it open to vent?
kmcormick9
oh and by the way in virginia, there is no real emmissions check on antiques, and in the DC area where they do check, you dont need anything if its before 75
Bret
I believe that your 74 is exempt form any further smog testing at this point in it’s life. So with that said – I’d dump all the emissions equipment as soon as possible. Plug the air rail holes on the head and cap off any air/vacuum lines that came from the manifold to the gulp valve.
As for the settings: You should be able to use the same settings from just about any MGB manual. Matter-a-fact the procedure for late model B’s (75-80) actually has you disconnect the air manifold hose from the air pump and plug the hose, while adjusting the air fuel mixture or it will throw off your CO readings.
Bret
[ 02-24-2003: Message edited by: Bret ]</p>
Bret
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by kmcormick9:
oh and by the way in virginia, there is no real emmissions check on antiques, and in the DC area where they do check, you dont need anything if its before 75<hr></blockquote>
I'll have to assume that 25 years is the standard in most states. However here in California the over zealous (Leftist) legislators, pandered themselves to the loony environmentalists – upped the normal exemption status from 25 to 30 years.
Beginning 01/01/03 Smog Check exemptions will apply to all cars 30 years or older and will continue on a yearly aging basis. According to my math – 74 model years are now exempt, but my 78 won’t be clear until 2008!!
AHGGG! I could just spit tacks just thinking about it.
Bret
Bruce74B
I've been running my '74 B without an air pump with absolutly no problems...and still use all the factory specs for tune ups. In fact, I have only ever seen one '74 B that still had the original air pump in it.
Bruce
A
aerog
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Bret:
<hr></blockquote>
That's ok... once 2008 comes around they'll force the checks on cars up to 40 years old
chris roop
If you go to the mgb experience site, there should be a pic of John Weimers desmog. A good start. New here, don't know how to do links. Use the Moss catalog to get to where you want to go.
Bret
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by aerog:
<hr></blockquote>
Go ahead & laugh. But as funny as that might sound to some folks – it has an ominous ring to it.
Currently, I’m looking into some sketchy reports at this time. But it looks like there is a vary real threat of something vary similar to this in the works in northern California right now.
See the new post in Austin Healy forum by new member JJS.
https://www.britishcarforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=000775
I’ll follow-up with more later.
Bret
kmcormick9
has anyone successfully converted their air pump into a supercharger?. just wondering....its there so its worth a try
WLJ
just to echo bruce's reply I have been running my 75
with no air pump for years.Just plug off the lines and use the factory ignition settings.
Warren
Celtic 77 MGB Seized air pump issue MG 25
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
M TR6 Air pump Triumph 0
rjc157 TR6 Air pump Triumph 1
rjc157 TR6 Air Pump Triumph 1
G Air pump removal Spridgets 3
G Air pump question Spridgets 18
pakiwi Air Pump Removal Spridgets 1
johnrip Wedge tr7 air pump bracket Triumph 2
pakiwi Removing Air Pump Spridgets 1
tweety no air pump, bad for the cat conv? Spridgets 2
AngliaGT Wedge TR7 Air Pump Triumph 1
chrisc Wedge TR8 Air Pump Injector Thread Size Triumph 11
G Does my air pump require any maintenance? Triumph 3
RSMTR8 Wedge TR8 Air Pump?! Triumph 7
PAUL161 Hose -- Air Pump to Check Valve MG 0
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
johnrip Wedge remove TR7 CATCONV and air pump removal Triumph 0
PAUL161 Lucas Air Pump Rebuild ??? Rick / Tony??? MG 14
johnrip Wedge TR7 air pump, and air cleaner Triumph 4
MrBlueSky Wedge tr8 air/smog pump?????? Triumph 6
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
RAC68 Cold Air Bilge Blower update Austin Healey 13
