TR4/4A What narrow belt on alternator conversion TR4a?
tdskip
Hi guys - got my pulley issue sorted so now I need - FINALLY - a narrow belt. For grins and giggles I tried a TR6 belt and it is to long. Anyone have a cross-reference handy?
Thanks!
TR4nut
Tom-
You may still need to go to a parts counter and find the perfect one, but this is working for me for a test fit on the 3A with a NipponDenso alternator:
Gates 7380 High Capacity V-Belt (Standard); HC41 13/32" x 38 5/8"
RockAuto has them for around $7.50
Randy
TR4nut
Its coming along slowly! Work and travel has gotten in the way a bit. I've refurbed the gearbox and od, but as yet still haven't mated the two together yet - its apparently a bit of an art form to get everything lined up perfectly. I'm hoping to get it together this month, then engine and gearbox mounted on the frame for a startup hopefully before the heavy summer hits.
TFB
TD,I think that you need know the pulley profile ,then get the right lenght.There seems to be many "thin belts" with small variations.
Moss uses metric wedge(vbelt)Quinton Hazell Qba 975,which is 10x8mm profile.
Tom
TR4nut
Tom
That's the one I hunted for on RockAuto originally, then I trolled around cross referencing until I found one just a little bit longer.
TFB
Heres a chart I was looking at when I thought I needed a shorter belt.I wound up cutting off the top half of steering box mount and the 975 worked.
belts
Tom
GTP1960 TR2/3/3A Moss alternator & narrow belt conversion questions Triumph 22
M TR4/4A Narrow belt conversion with thermo fan. Triumph 0
Lukens TR2/3/3A Narrow belt conversion. I can't understand why... Triumph 25
J General TR Narrow Belt crank pulley Triumph 0
croz TR2/3/3A Harmonic Balancer - narrow belt pulley Triumph 12
T Narrow Belt Conversion Triumph 7
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
S TR2/3/3A narrow wheel tr3 Triumph 13
Bruce Bowker Narrow tires Racing 5
Z Early BN1 Narrow Brake Drum Identification Austin Healey 6
D TR2/3/3A layout for lap type seat belt Triumph 5
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Overtightening the alternator belt? Triumph 14
D T-Series Shorrock supercharger drive belt MG 7
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
M 1972 Midget Seat Belt Replacement Spridgets 4
Lin Fan belt for 1275 with alternator Spridgets 4
nichola TR6 Seat belt reinforcing plate question Triumph 15
NutmegCT Belt preservative? Restoration & Tools 6
2 TR2/3/3A V-belt obstruction Triumph 0
Michael Oritt Seat belt anchors--introduction Austin Healey 2
T BJ8 Fan Belt Change Austin Healey 7
longbridgehealey Bonnet belt Austin Healey 16
B TR6 TR6 Fan Belt Triumph 4
F TR6 Seat Belt Module? Triumph 4
tahoe healey past post about sholder belt foam Austin Healey 2
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
B Wanted Kangol Seat Belt Receiver Jaguar Classifieds 5
B Wanted Kangol Seat Belt Receiver Triumph Classifieds 0
steveg BJ8 Alternator - small belt in large pulley Austin Healey 4
I General TR Seat belt dissassembly help Triumph 0
I TR6 Seat belt restoration Triumph 1
C TR6 Seat belt warning bypass for new harness. Triumph 6
KVH TR4/4A Belt Size for TR4A Triumph 4
G TR2/3/3A Fan belt Triumph 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
2billydavies TR2/3/3A belt size for TR3a? Triumph 13
C "Belt Type" squeal BN1 - Throw out bearing? uh oh... Austin Healey 14
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
J TR2/3/3A Changing fan belt. Triumph 9
C MK1 3000 fan belt Austin Healey 1
Lukens TR2/3/3A Cog v-belt causing noise. Triumph 8
Lin Pulley and belt configuration for air conditioning Austin Healey 2
T TR2/3/3A Question on spacer in Moss thin belt/damper conversion kit 837-508 Triumph 3
J TR2/3/3A Local fan belt supplier. Triumph 7
M TR2/3/3A 3/8" belt and pulley conversion kit Triumph 10
M TR2/3/3A Another seat belt question Triumph 8
Jeepster Seat belt fixing Austin Healey 4
B Gen/waterpump belt Austin Healey 13
