What is the size of a 1098 bored .020 over?
BrianN
Anyone know off hand what this works out to?
Thanks.
according to my handy chiltons bore x stroke is 2.543 x 3.296.
so i would say a +.02 would be 2.563
mark
Yeah Jeff, that would be great if you could take a 1098 bore it 20 thous over and end uo with a 2563--Keoke /ubbthreads/images/graemlins/grin.gif
oops guess i misunderstood that one...sorry
mark
Thanks for the info.
BTW, I chased down the oil leak to its real source.
The crank was cracked at two mains and one rod journal. It was bent .012" and chewed up the slinger retainer half ring and #3 main cap oil retainer half ring. The gap was over .012" I got a new crank, had it checked, ground, radiused, and polished. Then I masked the scroll and applied JB weld to the damaged ring area and temporarily bolted on the cap and half ring. When the JB was set, I pulled the parts off and hand worked the JB weld with fine sand paper until there was clearance, but not much, maybe about a thousandth or two. It is all back together now and works fine with no leaks. Just took time, money, and imagination.
