I upped the thermostat on my BN1 from 160 to 180 because on cool days at highway speeds the temperature would usually be about 160, and as I understand it engine wear goes up and efficiency down at low operating temps. And while I agree with Dave's point that a lower thermostat will essentially give more of a "cushion" in stop-and-go traffic, in practice those 10 or 15 degrees disappear pretty quickly once things start to heat up. On my car at least, a HD core took care of overheating at high speeds, but the auxiliary electric fan mounted in front of the radiator is a must when stuck in traffic. Even still, I sometimes experience very rough running once the fuel in the lines and bowls begins to vaporize. Maybe someone has come up with an auxiliary fuel system cooling system?
