DrEntropy said:...ya do NOT want to get any of it down between the bore and pistons. It'll scar the walls instantly...
DrEntropy said:... reassemble and use a spray bottle with water down the carb throats at 3K RPM. That burns off most of the kak in there without the chance the stuff will ruin the bores.
Back in the days when "decoking" or "decarbonising" was pretty much a routine maintenance item, many manuals suggested using an old piston ring as a "guide" to your piston-top scraping. That said, nowadays I think Tom's method is as good as any. Along those lines (and I'll try to be careful in wording this) there was the old proverbial "Italian car tuneup" consisting of running the "snot" out of the engine on the highway (kinda like what Tom did, although usually not 2000 miles' worth)!poolboy said:Kevin, if the pistons you want to clean are the ones in the engine in your driver, I wouldn't go overboard with the cleaning. I'd loosen some of it and vacuum the debris. Even Bentley says it's OK to leave the carbon around the perimeter.
tdskip said:How much water to you mist into the engine while it is running to do this?
tomshobby said:tdskip said:How much water to you mist into the engine while it is running to do this?
Only what was in some low clouds we ran through in the Ozarks between Sullivan and St Louis on the way home Sunday.
tdskip said:tomshobby said:tdskip said:How much water to you mist into the engine while it is running to do this?
So I have to wait until I'm east of the Mississippi to do this, or maybe go visit Don in Seattle. Oh wait, it never rains in Seattle anymore. <grin>
Seriously though (you knew that was coming), how much water?
