TR2/3/3A What is best tool, and best method, for widening gaps on TR3A grille?
TuffTR250
In a recent thread on TR3A overheating it was noted that some grilles may have smaller gaps between the "bars" of the grille and widening them would provide more air flow through the grille. I would like to widen the gaps on my TR3A grille even though I believe it may be a factory grille. I was wondering if anyone had widened theirs, and if there is some tool that would work the best. I'm leery of just using a plier with a narrow blade since that could make the metal quite wavy. Also, what is the best method for widening the gaps? I assume it would be best to do the work from the back side of the grille, is that correct? What method should I use to keep the corners of the gaps rounded, etc.? Are there any hints for how to do this and not make a mess of the grille? Thanks!
Regards,
Lbp
I too have been thinking about this since reading the thread (and since I recently installed the Macy's fan, an electric pusher in front, and the fiber board air duct in front, this is the next logical step to insure lower temps). I went to the British Sports Car show in Dixon, CA yesterday. I saw several TR3s side to side, some with the original grille and some with the replacement. The difference in the hole sizes was readily apparent. One thought I had was to widen the holes using a dremel tool with a grinding wheel. I don't know if the reproduction grilles are chromed or otherwise plated and if grinding open the holes would expose the interior metal and bring on rust. Any thoughts? Would this work?
Bill
Geo Hahn
I haven't done this (instead bought an old grille and straightened and polished it) but wonder if this might prove useful:
https://www.harborfreight.com/8-inch-flat-jaw-welding-pliers-93062.html
On mine the aluminum is neither plated nor highly polished though there may be some surface treatment (anodizing?).
doc50
I think I would make a male wood plug that would be the desired size of the biggest holes and leave the smaller holes alone (as they are to the side). A 'female' counterpart would need to be placed around the hole being worked on, to keep the grille from imploding. My feeling is that the female part could be nothing more than a molded wooden support that surrounds the hole from the back. The big holes, I recall, are the same size and since they are in the center, opening them would be the most effective.
Now I'm heading out to the barn to see what my grille looks like!
Thom
Triumph TR3
#TS34909L(O)
TomMull
Although I don't recall the previous thread that Bob refers to, before I'd start modifying a rather overly expensive grille, I'd remove the thing and see if the absence of the grille would make a noticeable difference in temperature.
Even if you find little effect on cooling, those grille's were a step down from previous smallmouth versions, in my opinion, and not the best of British engineering. Any talk of re-creating the old AMCO tubular grilles?
Tom
M_Pied_Lourd
Tom
Someone is still making a version of them....just wish I could remember the vendor that sells them. I will do some surfing...
Cheers
Tush
karls59tr
Bronze
The main problem with getting airflow to the rad is not so much the grille openings but the fact that the front of the cowl below the grille blocks 1/3 of the radiator. The fibreboard air duct below the cowl would direct more air to that part of the rad. I just have an electric fan in front of the rad attached to a toggle switch on the dash in case I get caught in traffic on a 90 degree day. I'm also running a TR6 yellow fan but might switch to the 2002 BMW red fan that has 5 blades and similar bolt holes.
I haven't had any issues with overheating but I should point out that I have the bumper removed and four 2&1/2" holes drilled in the lower cowl with a screen inside.
It also helps to run 37% antifreeze,13% water wetter and 50% distilled water.
I would really like to get one of those Amco grills or a reproduction of same if anyone knows of a source?:encouragement:
Geo Hahn
The main problem with getting airflow to the rad is not so much the grille openings but the fact that the front of the cowl below the grille blocks 1/3 of the radiator...
To try to improve that I use a crude but possibly helpful air dam to throw some air against the lower radiator when at speed:
Mounted with a couple of simple brackets - also serves as a 'curb feeler' for parking place stops:
T
TuffTR250
Geo, I think that tool may work good. I see from the specs that the jaws are 3-3/8 wide. Since the gaps in the grille are only just a little over 3 inches long, might have to grind off the ends of the tool to shorten the jaws. Thanks for the idea.
Regards,
NutmegCT
T
TuffTR250
Thanks Tom! I'm glad to see that the tool has been used for this purpose, and putting leather on the faces of the tool is a good idea! Did you have to shorten the width of the tool? It appeared to me that the tool is wider than the length of the grille gaps. Or how did you work around that? Thanks!
Regards,
NutmegCT
Regards,
Bob - just turn the tool 90 degrees, and use the "side" of the head (not the full width). I think in one or two very small slots, I used a simple pair of pliers, again padded with leather.
CJD
I'm usually a patient, meticulous guy...but this is a job I would not want to tackle! I'll stick with my ACME grill...
TRWisco
this is the first time I've ever seen this grille and I am blown away!!! That looks so good! I wouldn't even want to put the bumper on. would like to see how that looks with a little more of the car in a shot.
HerronScott
Wasn't that Amco?
ACME was the company used by Wile E. Coyote. :smile:
Scott
TR3driver
Great Pumpkin - R.I.P
Definitely AMCO
JPSmit some days your best tool is a credit card Spridgets 2
J Best tool for getting help in the garage. Restoration & Tools 13
beaulieu best tool to remove old bondo ? Restoration & Tools 14
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
