T
Tinster
The TR6 and it's foibles continue to amaze me.
Replaced the rocker arm shaft and cleaned everything
spotless. Installed said rocker arm assembly.
Set valves at .010 , pre-set timing at 10* advance, new rotor:
car started on full choke with some difficulty. Next day, fine
tuned valves- car started with great difficulty and full choke.
Day 3- car will not start at all- no spark.
I replaced plugs, rotor, plug wires, dizzy cap and condenser can.
Car wouldn't start. No spark anywhere. Charge battery overnight.
Bumped dizzy out of timing- set dizzy by static timing method.
I replaced coil, again bought all new plug wires and new coil to dizzy wire,
again bought new spark plugs.(tested new coil- nice spark)
Let battery charge overnight.
Today.
Reset points to .012 gap, new plugs gapped at .030, valves regapped to .012,
dizzy still at static time.
Car would not start on full choke but sounded like it wanted to fire up.
Loosened dizzy and with remote starter button, slowly
rotated the dizzy while trying to start the engine. Zing!
The engine fires up into a smooth running beast. Quickly ran on no choke.
But the dizzy position sure looks odd to me.
A few hours to cold engine, turn the key on 1/2 choke-instant start,
smooth running. Performed a by the book timing test-
the engine is running beautifully at -0- advance. Cannot hook
up rpm cable or 2 small vacucum lines because of angle of dizzy.
Engine dies immediately if I try to rotate the dizzy counter clockwise.
Here a photo of my dizzy. NO I did not touch or lift
the dizzy body at any time.
All theories concerning my fine running engine at -0- advance
welcomed. Something is messed up but I've no idea what.
thanks as always- I need a detective.
Dale(Tinster)
Today.
Dale(Tinster)
