wkilleffer
Ok, you're probably familiar with the new head gasket I've put in my 74 MGB. I'm trying to drive it more than before. Today, temp got up to around 70deg with some winds. I drove the car on a couple of errands, like to the bank, where I went in a place for about 10 minutes, came back out, and started the car to drive off. Car would start, but would idle low and kind of rough, and smelled kind of like rich exhaust. After I got out of the parking lot and on the road, it seemed ok.
Now, this worries me cause it was a bad problem with the car last summer, and right or wrong, I kind of associate that with some of the problems the car was having.
Some of the things I've done lately:
-New head gasket and retorqued after several heat cycles
-Rebuilt head
-Radiator rodded out and repaired
-180deg thermostat
-New coolant and hoses. Coolant level is just below the neck of the radiator
-Oil and filter change, 20w50 Castrol GTX
-Adjusted timing, 2 or 3 deg over factory spec, no pinging on 93 octane so far
-Adjusted valve clearance while engine was warm, can still hear tappets but they're not loud
-Balanced carbs. they may be slightly rich, but they were breathing at the same rate when I put the air cleaners on
The temp gauge needle will come very close to the N, but won't get straight up and down with it nor go past it.
I've been driving it a little more enthusiastically than I used to. 3500 rpm shifts are starting to become the rule rather than the exception.
Call me paranoid, but I don't want to think that I've done all that work only to have something else go wrong or have to do it again next week. If I can think of anything else, I'll post it.
Thank you,
-Bill
-Rebuilt head
-180deg thermostat
Thank you,
-Bill
Hi Guest!
