TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing?
TuffTR250
On my 61 TR3A what would cause fast flashing of the turn signals even though all 4 lights and the indicator light are all lighting up? It was my understanding that fast flashing usually meant one of the bulbs is not working, but it this case they are all lighting up. Thanks!
TR3driver
Great Pumpkin - R.I.P
Re: What causes fast flashing turn signals when all bulbs & indicator light are flash
Anything that reduces the current can cause that.
Make sure you've got the brighter filament lighting at the front; and that you've got the right bulbs installed (no LEDs).
Look for a bad (high resistance) connection. Can happen almost anywhere, but I've had the most trouble with the 4-way bullet sleeves. Sometimes the internal spring conductor can crack and not conduct very well. Not common, but I have seen control heads where the contacts were worn until they didn't make good contact.
I've even heard of it caused by a wire that corroded inside the insulation.
One trick that might help run it down is to install a jumper across the turn flasher. That will give you constant voltage at the bulbs, to make it easier to check the voltage with the bulb installed.
If all else fails, try a different flasher.
CJD
I've always found that a higher load causes fast flashing, as it heats the flasher element quicker. Plug in a trailer and flashing usually speeds up. Since all your lights are working, my guess is a new flasher element would fix it.
T
TuffTR250
Thanks! I'll try the new flasher first. That's the easiest to get to.
T
TuffTR250
A question: will an electronic flasher work with regular bulbs? Or would I be best to switch to LED bulbs in the turn signals? Thanks!
Geo Hahn
My experience was that a lesser load (1 bulb out, dimmer filament used, LEDs installed) caused fast flashing.
A load resistor in parallel is one way to address this when using a conventional flash unit - a common way to make LEDs work.
That said, on one of my cars (VW) LEDs in the rear lights sped up the flashing but I actually kind of like the effect (i.e. more annoying / noticeable).
TR3driver
Depends on the flasher. I use a Tridon EL-13, which was readily available at FLAPS and works great (but probably wouldn't work right with LEDs). All of the others they had in stock would not work right in the TR3A circuit. (Yes, I tried a sample of every 3 terminal flasher they had in stock.)
I would think that most LED-rated flashers would work as well, but it might be tricky finding one that will correctly drive the dash lamp and you'll probably have another wire to hook up. I used a load resistor instead (as Geo mentioned).
T
TuffTR250
Randall, I've found Novita EL-13 in local FLAPs but not Tridon EL-13. For a TR3A does it need to specifically be Tridon? Thanks!
p.s. I plan to stick with conventional bulbs for turn signals
TR3driver
Geo Hahn
Here are the load resistors I used to slow down the LED blinkers:
I used bullets on each end for a 'no cut' addition to the loom (one end to the turn signal wire, the other end to ground. Magnets on the bottom let me tuck the resistors out of sight (e.g. on the inner wing under the apron).
CJD
The resistors work great, but sort of defeat the main advantage of LED's...lower current draw. It might be best to swap the flasher to take full advantage of the LED's?
TR3driver
Who cares how much current the turn signals draw? They aren't on long enough to even include in a power budget!
The main advantage should be that they are much brighter than the stock bulbs.
CJD
I assume you mean much brighter for the same current draw, since you can also get brighter Edison style bulbs too.
TR3driver
If you know of an incandescent bulb that will fit the sockets and put out 2 to 4 times as much light, I'd sure like to hear about it.
A very brief video. The light on the right is an uprated incandescent, about 25% brighter than a standard 1157. On the left are several LEDs, drawing a total of about half as much power.
https://m.youtube.com/watch?v=q4GMcD9DktQ
PS, my tr3 didn't come with separate turn signals in the rear, so I've modified the corner lamps to serve triple duty as stop, turn and tail lights. The video shows brake lights, but the turn signals are the same.
Geo Hahn
LEDs aren't merely brighter - they are more abrupt (there's probably a term for that). When they flash the on & off are more immediate and (my opinion) more effective.
T
TuffTR250
Wow Randall, that Novita EL13 turn signal flasher did the job!! The turn signals are all flashing as they should, including the dash indicator light. I got it at a CarQuest store. Thanks for the tip on that flasher!!
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
J MGB What causes this puzzle? MG 4
H blow by oil pressure causes oil to leak out of the dip stick tube. Austin Healey 12
B Clutch causes engine to stall? Spridgets 5
K Common causes of Differential Seal leak? Triumph 13
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
boeingpilot What causes "run on" Triumph 9
58Custom What causes popping out of first? Spridgets 0
T Breakdown causes? Triumph 7
T What causes an engine to backfire? Triumph 15
Luke_Healey Causes of dieseling on shutdown? Spridgets 21
wkilleffer What causes heat soak, and is it a bad thing? MG 16
A Heat in engine bay causes idle to drop? MG 37
K Coolant in oil likely causes? Triumph 6
Mark_Gibson TR6 TR-6 Positive Rear Wheel Camber Causes Triumph 8
J uneven camber-- causes? Triumph 9
J Lack of Diesel Engine in Europe causes slowdown in X type sales and production Jaguar 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
Hamish Racing TR2/3/3A Fast Road TR3a on figure of 8 sprint track - UK Triumph 10
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
HalLucy Post-War Other Renown - Idle too fast Triumph 5
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
P Fast Healey at Lime Rock. Austin Healey 2
wkilleffer MGB Air leaks and fast idle speed MG 11
HealeyPassion AH Spares Fast Flow Manifold.... Austin Healey 32
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
T TR2/3/3A 1/4 mile fast time driving technique Triumph 15
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
DerekJ Indicator blinking too fast Austin Healey 13
D Piper Fast Road Cam Installation Austin Healey 9
D Fast Road Cam Austin Healey 2
B Fast Idle Spridgets 7
steveg Fast and the Furious on Friday Oct 25 Austin Healey 2
glemon Better Move Fast Spridgets 4
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
KVH Idle Too Fast Triumph 36
drambuie Old British car film..... The Fast and Furious 1955 full movie Austin Healey 17
L Fast idle? British Motor Corp 4
StagByTriumph GT6 1968 GT6 for sale in Colorado Auto Parts Salvage - act fast Triumph 8
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
lbc_newbie MGA Someone needs to get this, fast... MGA $1500 in SC MG 4
HerronScott OT: Honest officer, I wasn't going that fast... Triumph 8
C An MG in fast company... Racing 0
HealeyRick The Fast and the Furious XK 120 Jaguar 2
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
MadMarx [video] Zandvoort - fast qualy lap Triumph 11
PAUL161 Stirling Moss in one fast MG! 1957 Bonneville! MG 7
