58Custom
I got a set of new tires a while back when I was getting this '69 Midget going. They were balanced by the shop after mounting with new tubes. At that same time I was doing a lot of stuff to the car, so I dropped off and picked up the tires off of the car. I refreshed the engine and installed a good used differential chunk and changed the rear U-joint and other things. Prior to this I had not driven the car faster than 30 mph.
After all of that I found that I had a pronounced vibration at 60 MPH and above. I rotated the driveshaft in relation to the diff 90 degrees but it really didn't make any difference.
I rotated the wheels fron to back, but there was no real change in the vibration.
Yesterday I lifted the rear and spun the tires by hand and noticed a slight side to side wobble at the rim of about 1/8 inch. I started the car and spun the wheels (4th gear) to 60 and felt vibration. I let it idle in 4th and noticed that the tires appeared to be out of balance. That is the wheels seemed to rotate concentrically, but the tires appeared out of round like it was unbalanced.
I have read in the scans of factory docs that the tire installer must use special tools to balance the wheels. The tire places near me do not have anything but the usual install stuff.
The tires are 155/80R-13 Milestar Touring SEs. Except for problems with their trailer tires in the past they seem to be ordinary, decent tires. The wire wheels are old, but not loose. They don't flex from side to side.
Thoughts? Experiences? Advice? Admonitions?
