I'm not sure what compelled me to go out into the garage this afternoon at the time that I did, but I'm glad I did. It was probably so I could admire the tidiness of my garage after a 2 week cleaning spree, knowing it won't last long. Anyway, as I was out there admiring my clean garage, I heard a hissing sound and saw what looked like water dripping from the ceiling onto the water heater below. My first though was that mice had chewed through the small diameter PVC tube that runs from the water softener, up into the attic area above the garage, and over into the kitchen area and the Reverse Osmosis machine. The tubing was in just the right spot to have been causing a leak from the ceiling in that exact spot, but I could not find any leaks in the PVC tube.
After some careful sleuthing, I discovered the leak wasn't coming from the ceiling at all, but rather from the copper flex pipe on the hot water side on top of the water heater. There was a pin-hole leak in that copper flex pipe and the water was squirting up and hitting the ceiling, which then was dripping off the ceiling so that it looked like the leak was coming from the ceiling. I had to look very hard to see the tiny spray of water from the water heater pipe (in fact I found it first by feel, not by sight).
So I turning off the main water valve inside the house and the tiny leak eventually died off. Then I drove 30 miles into Albuquerque to buy a new 18" flex pipe (which would need to be soldered on on the one end and then there is a screw fitting on the water tank side).
Anyway, I got to Home Depot and found the required flex pipe, only to discover I had left my wallet at home! Arggg! So I drove back home, got the wallet, then back to Home Depot to buy the flex pipe.
I just got finished installing the new flex pipe and now we have running water once again (and it's after 10PM!). Now I just have to repair the damaged drywall in the ceiling where the water damaged it.
Ah the joys of home ownership; but at least I'm glad I didn't have to spend $250 to have a plumber come out for the repair.
