wet insulation
NutmegCT
How would you dry out sound insulation material after it got wet (heavy rain, window open ...). Carpet is removable, but not insulation between carpet and steel floor. It's like fiber carpet underlayment - not like foam or Dynamat.
The insulation is glued down!
Thanks.
Tom M.
TR3driver
Great Pumpkin - R.I.P
Put an incandescent light inside the car and leave it on for a few days. The heat will help it dry out.
The alternative of course is to pull up the insulation and replace it without gluing it down.
NutmegCT
NutmegCT
Thanks Randall. Wouldn't the bulb heat just warm the entire area, without removing the moisture from the insulation?
(I agree - I think ripping it all out and replacing without glue is the path.)
Gliderman8
You also might try laying some towels down first for a couple of hours to wick the moisture into the towels. Then do as Randall suggests. The heat should help dry it.
TR3driver
Warming the air also serves to dehumidify it. Surely you've noticed how dry it is in the house in the winter with the heat on? (Unless you run a humidifier of course.) The same amount of water that would cause 100% relative humidity at 40F is only 25% or so at 80F. The warm, relatively dry air will greatly reduce the drying time.
LarryK
Open doors or windows and circulate the air with a small fan. Dried many cars this way. Heated garage and a fan.
TomMull
It will dry eventually but if prone to repeated soakings, the glued insulation is not a good idea, in my opinion. I'd get rid of it. It is usually glued with contact cement and comes out quite easily. It is a bit of work to get rid of the residue but worth it. You get to see what is underneath too. I don't know what you are working on but the fitted insulation is available for most LBCs. Alternatively, fit the carpets with no insulation. Tom
NutmegCT
NutmegCT
" ... the glued insulation is not a good idea, in my opinion. I'd get rid of it. "
Agreed!
Thanks all. Onward through the fog! (and slush, and sleet, and ice, and ...)
bgbassplyr
You might try a wet/dry shop vac followed by the light bulb. Place a bit of screen wire over the end of the nozzle to prevent vacuuming up the insulation.
Steve
Platinum
There are also products that absorb moisture in a car, rather like silica gel. Worked like a treat over a couple of weeks in my wife's Passat after she left the moonroof open and a heavy storm moved through.
Hamish Racing General TR 3 sisters sprint (uk) the wet one Triumph 2
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
S TR2/3/3A Wet liner issues Triumph 6
DerekJ How to drive a Healey in the wet! Austin Healey 6
D TR2/3/3A Sealing Fo8's and Wet Liners Triumph 6
S TR2/3/3A wet sanding and amonut of paint Triumph 13
RickB MGB Crane Cams XR700 Fireball - wet conditions? MG 7
J Wet carpet Austin Healey 16
2billydavies TR2/3/3A Replacing the pistons and wet sleeves Triumph 15
Frankenhealey Goodwood Spring Sprint - It was WET Austin Healey 11
K Figure of 8 Gaskets for Wet Liner Engine? Triumph 5
G Tires for wet conditions Spridgets 4
jsfbond Wet snow conditions Triumph 3
M Wet Carpet MG 13
PatGalvin TR2/3/3A Wet Sleeve to Engine Block Deck Clearance, TR3A Triumph 4
T Think this explains my wet foot? Triumph 24
K Wet trunk Jaguar 1
livinginthepast Bugeye gets wet and wild ... Spridgets 5
Tabcon Thread Sealer on Wet Liners? Triumph 5
Tabcon Thread sealer on wet liners? Racing 0
TR4nut Wet Liner Engines & Valve Interference Triumph 18
equiprx I keep gettting a wet dizzy. Jaguar 1
T Click and Clack are all wet.... MG 2
C Wet left foot? Triumph 8
AltaKnight A wet weekend Triumph 1
RickB MGB-GT 70 BGT floor gets wet when it rains MG 23
beaulieu Wet sandblasting - anyone done it ? Restoration & Tools 1
7 Wet Sanding Austin Healey 22
G Wet & Wild Ride... Triumph 3
AUSMHLY wet rugs Austin Healey 21
Z Tire wet look Restoration & Tools 2
Patrick67BJ8 Insulation and Sound Deadening Austin Healey 0
FlyingCat Spitfire Insulation Triumph 2
Walter74 Insulation set from Koolmat Austin Healey 3
EWD TR6 Transmission tunnel insulation Triumph 6
NutmegCT Garage roof insulation Restoration & Tools 37
Jim_Gruber Heater Box and Insulation for Bugsy IV Spridgets 8
Rut Bugeye bonnet insulation Spridgets 4
D Fire wall insulation Austin Healey 36
M TR4/4A Underhood/Bonnet insulation...Yes...No ? Triumph 3
maxwedge5281 under floor insulation Austin Healey 15
L 3000 BN7 insulation Austin Healey 11
H quick insulation paint color quesrion Austin Healey 7
Griz Cockpit Insulation Austin Healey 13
R Interior cockpit coatings and insulation Triumph 12
M Insulation Done [pics] Triumph 6
F Wire insulation damage under the dash - Bugeye Spridgets 5
R Another insulation question Austin Healey 3
B insulation to the footwell Austin Healey 21
