Hi Larry,
I shopped around a lot last year and ended up with a Hobart 140 kit that included a decent little cart and the gas controls. Those items are sometimes separate expenses.
I added a storage cover, slag hammer, some spare supplies including extra tips, good gloves and a better helmet than what came with the kit. Got a great deal from one of the online sellers... maybe Northern Tools or Harbor Freight, I forget which. Free shipping was nice! It can be pricey since the welder is pretty heavy.
While shopping, one thing I heard over and over was that the Hobart wire feed tended to be better functioning or more reliable/less likely to jam than some other welders in the entry-level "consumer" range. I also specifically wanted a 110-120V welder for now. Otherwise I probably would have opted for a Hobart 180 for greater duty cycle and thicker material welding.
On arrival, one of the hinges and a control switch were broken on the Hobart... shipping damage. I called them direct and they had new parts to me the next day at no cost to me. Super fast service! They just asked me to return the broken parts to them, and provided a postage-paid envelope for that purpose.
I've only been using the 140 so far just with the flux core "gasless" wire such as was included in the kit. I think .030 or .035 was supplied. I had another roll on hand already, too, and can't remember which came in the kit. If changed to .020 or .023" wire, I believe the wire feed sleeve also needs to be changed to work right. Easiest way to do that would be just to get a second torch and cable/wirefeed/hose setup. There is some added cost to this though.
Flux core wire is a bit spattery and I plan to get the gas soon and switch to using solid wire/shielding gas instead, for nicer welds and better control on thinner sheet metal. I found a local supplier quoted about $100 for the initial small tank purchase and fill, cheaper refills after that (maybe $30?).
I've been using oxy/acetylene for many, many years and MIG/GMAW is a bit different, probably easier to learn initially but still needs some practice. I'd probably really benefit from taking a class, too. Good idea. Might even pay to wait to purchase after you have taken the class.
One thing I changed my mind about was welding aluminum. I'd originally planned to use the 140 for that too. It can be done, from what I understand, but I think I'll wait and get a spool gun welder especially for that purpose eventually. The problem is feeding aluminum wire all the way from the main compartment of most welders. Apparently that often jams. A spool gun, with a small spool of aluminum directly behind the torch head, works better with aluminum wire. Meanwhile, I can still weld aluminum with oxy/acetylene (special flux and goggles are required).
I'd love to have a TIG eventually, too, but am not holding my breath. I'll probably get a plasma cutter before I get a TIG. Both will have to wait until I win the Lottery, though.
Cheers!
