Welding tips?
Sportsdoc
I tried over the weekend to weld my new battery/heater shelf with some success. I borrowed a MIG welder, but my welds were spotty. Any tips on making a nice smooth bead?
I fooled with high and low heat settings and wire speed without much difference. Also turned the gas on but no change.
Thanks.
Always use the gas, use the highest voltage you can without blowing holes through the steel. Proper tip angle used with a pulsing ON/OFF approach will keep the puddle heat just right and prevent melt-through. Pulsing the trigger is a big help.
Glen Byrns
Clean metal is also very important.
Do a search of the "Tools" forum here on the BCF. There's a couple threads about welding that might be handy. Good luck!
what type of mig welder, Amps, brand are you using. Generally mine does very well on the lowest possible volt setting with a wire speed of four and gas on 30. (for sheet metal repairs) But they're all so different. Took me half a year to get my welds "close to perfect"
Rather than lay down I bead, I would try a puddle weld, which would resemble the original spot welds and much, much easier for a novice.
A novice I definitely am, so I will give these techniques a try during my next garage session.
I much prefer the flux cored wire without gas. That way if you feel you are burning through a thin metal then you can back off and let the wire come wire come out farther and don't burn in as deep. wiht the gas you can't do that. Not as clean a job but much better on old thinner or rusted metals. Great on exhaust pipes and such.
