[ QUOTE ]
Hello Dave,
thank you for that, I have noticed that we use a different nomenclature for body parts this side of the world. I was assuming some inner flat(ish) panel around the engine bay or radiator.
Alec
[/ QUOTE ]
Hi Alec,
Your fellow countrymen actually named the part. We would likely call it something else.
On a "Big Healey", the front shroud actually consists of the entire aluminium center section of the body from the bumper back to the dash board & between the two front mudguards. A rather complex, multi curved item. There is also a rear aluminium shroud that covers everything from the cockpit rear to under the bumper & between the two rear mudguards. It is also has complex contours. These parts are partially the reason that the Healey is so expensive to restore.
There can be an electrolytic/galvanic action between the steel mudguards & the aluminum & under the right conditions will errode the aluminium shroud flanges severely. Healey owners are especially careful to avoid winter salted road conditions. At around $4,000 USD for a front shroud & $3,500 USD for a rear shroud, these two bare bits of aluminium represent more than the entire cost of some other cars. To make things worse, new shrouds almost always require custom fitting/reworking to fit the hand made nature of the bodies. Usually great pains are taken with the painting to fully cover & isolate the mating flanges of these parts for electrical insulation. Some have even tried sacrificial Zinc strips in the joints.
