TR2/3/3A Welding hoods.
sp53
Those welding hoods that have the dimmer built into the lens or whatever. Anyway, I bought mine at HF and it worked well-- I think, but know I am not sure. Is there a way to test the blink to dark on them?
S
sp53
John the summers are beautiful from July 10th to about September 30th. Then the weather is back to lots of rain with the high and low at about 48 degrees constantly.
CJD
If you have an oxy/acetylene sparking igniter, or a flint cigarette lighter, if you spark it in front of the hood it will dim. You can then use that to adjust the darkness and time it delays before undimming. Having used the automatic helmets for about 15 years now, I can’t imagine welding without them! You were completely blind with the old helmets until you got the weld going. The only down-side is sometimes the angle you have to weld obstructs the photo-cell on the dimmer, so it doesn’t dim...nasty retina burns on occasion.
S
sp53
Heck I thought there might be a battery in there. Then I thought it was some kinda of flash deal that might not need one. I will check that today.
LarryK
I look up at my lights to see if it darkens. Seems glass is dark enough to offer some protection as I forget to turn it on. Eye doctor says things are fine now, but remember to flip switch.
dklawson
The batteries in the older HF units are not easily replaced. If you don't find a removable door for battery replacement, visit YouTube for information on how to modify your helmet to use external cells. I modified mine and continued to use it for a couple of years until it became my backup unit.
CJD
The original dimmers had on/off switches, and I tended to forget to turn them off and ran many batteries down. The latest versions don't have switches...guess I was not the only one who forgot.
Tr3aguy
On mine I made sure to get the one with AAA batteries. The older ones had the little round style ones a real PITA to find. I even got 4 rechargeable ones and I just swap the out before I begin welding
S
sp53
I dug out my instruction book from 1999 when I bought mine, and I cannot see where it talks about batteries. It mentions sensors and to clean them. There is a small box inside where I guess some batteries might be if it takes those flat ones. Anyways the hood is a little dark all the time and when light comes in everything is brighter. I used it yesterday and everything was bright, but again I was welling. Heck I started to just close my eyes and count to 3.
DavidApp
Went to HF yesterday to get one of their Vulcan Arcsafe helmets. I had a 20% coupon that would expire on 8/2/20 Got to the register and was told the coupon did not cover that item. It said so in the micro writing on the card.
Going to Northern Tool today with a $20.00 coupon for their Lincon helmet. That one also uses AAA batteries.
David
CJD
Steve, if your helmet is that old, I think you will be pleased with a newer version. They have larger viewing areas, more control over the amount of shade and time it stays dark, and are a fraction of the price they used to be. My first self dimmer was over $250. My current one is under $50...so cheap I almost was afraid to use it, thinking “you get what you pay for”. But, it has done well for the last year.
PeterK
I have a Lincoln Viking 2450 which has a large viewing area unlike the cheapo HF eye slit. The 1740 model is less than $130 with great features and can use the magnifier lens inserts. I became afraid to use the HF one I have. When it's safety, I don't cheap out.
David
TomMull
I've made somewhat of a collection of these over the years. Two from Eastwood and at least 3 from HF. The latest is the Arcsafe top of their line from HF. I can find no fault with it and it is far superior to all the others. I would have gone for the Eastwood XL9300 but HF had a sale and I was in the store. The Eastwood service and warranty has been amazingly good in my experience.
The Lincoln and Miller helmets have been competing with the Chinese(?) helmets price wise lately but I have never tried one.
Tom
Tr3aguy TR2/3/3A Welding in Frank’s bump stops Triumph 0
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
L Welding Bugeye Spring Base Plate?? Spridgets 1
D Off Topic welding fumes Triumph 5
R TR2/3/3A Welding in the floor questikns Triumph 19
dklawson Antra Auto Darkening Welding Helmets? - 2016 Restoration & Tools 6
KVH General Tech Welding, Braising, Tacking Triumph 3
R TR2/3/3A Question on order of welding Triumph 31
S TR2/3/3A welding battery box Triumph 6
Rut TR4/4A On or off frame when welding in body panels Triumph 16
Jim_Gruber Bugsy II - Planning some Welding - Part II Spridgets 18
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B 1275 Block Welding Spridgets 14
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
S TR2/3/3A welding slag in the carb tr3 Triumph 8
wangdango inner body panel painting/welding/etc Austin Healey 3
I bugeye bonnet welding help please Spridgets 11
J Welding advice please Restoration & Tools 9
boxfullofyertoys Thoughts on DIY welding/bodywork Spridgets 27
Morris Welding fun! Spridgets 9
K Modern Epoxy instead of Welding? Triumph 13
TRMark New Welding Helmet Restoration & Tools 3
M Welding 101. Triumph 1
hymodyne rear quarterpanel repair section welding Restoration & Tools 10
M_Pied_Lourd TR2/3/3A TR3A Floor Welding Question Triumph 8
T cast iron welding info and repair-FYI Triumph 1
ekamm welding tr3a inner sill Restoration & Tools 2
T Inner fender progress - welding pictures Triumph 17
germanmichel The story of the bad weld seams with MAG-welding.. Restoration & Tools 4
1965_MGB MIG Welding Anyone? Restoration & Tools 8
1965_MGB Gas Welding Anyone? Restoration & Tools 8
TRMark Welding Table Outlets Restoration & Tools 5
Popeye Welding butt joints... crack in weld after grindin Restoration & Tools 3
M Welding the Exhaust vs. Electrical Problems Spridgets 5
motofiaccone Welding in panels Spridgets 5
MGBGT_noob The great welding method controversy MG 12
M welding advice Triumph 5
T Aweman, I have a welding question, you there? Triumph 6
T Wedge Nearly done welding the TR8 floor repairs Triumph 15
T More welding quesitons - how much overlap? Triumph 9
T Question on seam welding - why not do it? Triumph 18
dhungerf Welding Patches? Triumph 11
A TR2/3/3A TR3 head welding Triumph 4
J Welding aluminum water neck Austin Healey 3
T First stab at welding Triumph 12
v8mgbal welding Spridgets 36
S Welding sheet metal Triumph 17
EastBoundJoe Welding newbie Spridgets 39
Popeye Welding: Butt- or Lap? Restoration & Tools 12
vping Welding to a rear axel tube. Can you? MG 17
