Do some of you welders have a second to offer some advice. I am trying weld an 1 ½ pipe out rigger with a homemade stiffener with my mig. Trying to figure out if I should slow the speed of the wire down on the welder with the voltage high---- then start welding at 80% angle or all most vertical on the pipe---- about a ½ inch up on the pipe from the base and let them melt together as I go up and down with the tip/wire in a kind vertical weld.
Or perhaps hold the gun end more horizontal with the frame and try and going in a circle around the base of the pipe over the top of the old weld, basically try and weld it the way they did.
Or better yet a great idea on how to weld it.
steve
steve
