Aoha Ed,
As Randall & Geo have said, the brass compression sleeve is the thing that makes the seal against the inside flare of the pump outlet. Much like the flared end of a brake line causes a seal. The nut ony needs to be tightened enough to crush the brass against the pump. Continuing to tighten will only lead to worry about stripping the threads in the pump.
If you have recently removed that connection from the pump, it is possible a small bit of dirt may not allow a good seal, or the brass sealing surface was nicked.
Teflon tape on the treads will not seal the fitting IMO. Perhaps a turn or two around the compression sleeve might work. An alternate possibiity is a fuel resistant O-Ring inserted in pump outlet to seal between the pump and the compression sleeve.
Good Luck and Merry Christmas.
