PeterK
Yesterday I finished adding disc brakes to my single axle aluminum trailer. It's surge accuator system that has a coupler that moves in when you brake to push on the m/c. Rewired the trailer from a flat 4-pin to a round 7-pin socket to get backup light voltage to disengage the pressure on the discs so I can backup!
Today I swapped the rear leaf spring bushings from old cracked rubber to new poly. I cleaned and lubed the rear 10" drum brakes, blasted and repainted the drums and the spring shackles. I also topped up the lever shocks; I use a small syringe that dog worm medicine come in, and squirt the fluid in until it runs out of the hole.
Yesterday I also made a small bracket to mount a Hella halogen backup light on the outside of the driver side rear bumper bracket. Since the Toyota 5speed already has a backup switch, I figured I might as well use it. Looks vintage. Haven't tried it at night yet though.
And finally got around to hooking up the brake light modulator/flasher. This thing is REALLY cool and I will post a video of the light in action - you can't miss my brake lights now. While I was in the trunk I cut a new trunk carpet from a roll that I have in the loft. I just can't stop!!!!
So I'm running out of parts, guess I'll have to take a trip.
How's everyone's weekend going?
