ChrisS
I spent a little time after work today down in the machine shop with a spare crank I have. A couple of the journals were marginal for needing a grind so I didn't care to much about it. I set it up on the milling machine to try and wedge it myself, below is the result. I think I'll get it balanced next week. For those that care, with a 2' main / 1.625" rod journal I set it up will parallel blocks such that the bottom of the rod journal was 0.500" above the base on the main. I then cut down the crank until it was 0.425" above the main journal. I don't know if this is what APT does but it seemed to work out pretty good for me.
