Wedge Wedge liners
DNK
OK, Naive guy here. Can the cylinder liners on a V8 be taken out from the top?
tr8todd
They press in from the top. Machine shops charge around $100 per liner to replace. "Slipped" liners are common on later motors. From what I understand, the original liners are somewhat shorten than they should be. There is a lip at the bottom of the bore that the liners never contact. Replacement liners are longer, get pressed all the way down to the lip, and then get machined smooth with the top of the block. Slipped liners will move up and down inside the bore as the piston moves up and down causing a terrible knocking sound as it bounces off the cylinder head and the lower lip. The only way I know to remove a damaged liner is to bore it out.
DNK
DNK
So the motor has to come apart I take it?
DNK
DNK
Just doing some preliminary questioning. Hopefully all for not.
WedgeWorks
The rover V8 liners are a "dry liner" versus the TR2/3/4s with "wet liners". Unless you have to I would not recommend messing with the liners too much. Even boring the motor may "disturb" the liner causing it to move and leak on the post 3.9 and 4.2 blocks. If it is the original 3.5 you can bore the engine up to .060" and have enough left to feel comfy.
Tr4dude
If the block has to be bored for an oversize liner for any reason u should have the machine shop pressure test it. I have done many a sleeve job where the block has porosity issues and the new sleeves leak during pressure testing.
TR3driver
Great Pumpkin - R.I.P
I must be misunderstanding something here ... if you are putting a sleeve in the cylinder, why does it matter if the block is porous? Nothing should be able to get through the sleeve.
WedgeWorks
The propblem with a porosity/porous block is the liner may develope a leak between the liner and the aluminum casting. Additionally the prorous material may crack between the thin material that eventually will lead into either a water or oil jacket and worse a head stud hole. These issue only occurs on the 4.0/4.6 liter blocks with 4 bolt mains and some early 2 bolt main 4.2 liter blocks.
DNK
DNK
tdskip said:
What is the motor doing/no doing Don?
Sorry for the delay Tom.
Just got back from the wilds of Puerto Vallarta.
I think what might be a Hy. valve noise I am afraid to find out, might be a liner problem.
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
David Townsend Wedge Limited Edition Wedge Prints Available Triumph 0
jfarris TR2/3/3A Thumb Screws for Wedge Side Curtains Triumph 4
PATR8 Wedge Help.... Wedge stalling out Triumph 1
Got_All_4 Wedge I need a new one of these. Wedge ac experts Triumph 5
PATR8 Wedge Where have all the Wedge owners gone Triumph 5
Marvin Gruber TR2/3/3A Need a pair of Wedge type side curtain mounts Triumph 3
aeronca65t wedge parts car for sale - NJ TVR 2
mgedit Wedge Wedge Style Sidescreen ... Picture Request Triumph 8
DNK Wedge Wedge Triumph 3
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
John_Mc Wedge Nice Wedge Triumph 6
glemon Wedge Is that all the love a Wedge gets? Triumph 14
DNK Wedge Wedge WP Triumph 2
PATR8 Wedge Wedge help needed Triumph 7
Darrell_Walker Wedge Wedge radio mounting Triumph 16
Darrell_Walker Wedge Drove the Wedge to work today! Triumph 6
K Wedge Taking the wedge to the Cape- Triumph 4
Darrell_Walker Wedge Reassembling wedge front suspension Triumph 6
glemon Wedge Low Mile Wedge Triumph 7
Darrell_Walker Wedge Removing Wedge strut cartridges Triumph 13
justin_mercier Wedge Took the wedge out for a little spin. Yay! Triumph 14
Darrell_Walker Wedge Wedge wheel adapters Triumph 14
Darrell_Walker Wedge Thought exercise - a wedge as a daily driver? Triumph 86
jclay Wedge Texas Wedge Ralley and Picnic! Triumph 10
John_Mc Wedge Wedge parade Triumph 7
WedgeWorks Wedge Wedge Tree Triumph 9
DNK Wedge Wedge Pumpkin Triumph 18
T Wedge BMW Recaro seats in a wedge Triumph 22
deadair Wedge wedge mount side curtains Triumph 11
philman Wedge good looking wedge on pdx craig's list Triumph 11
G Wedge A/C TVR 4
DNK Wedge Wedge PS Hoses Triumph 0
G Leven Hood Cover for a Wedge TVR 1
T Wedge Another Wedge head has joined us Triumph 60
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
P Wedge shaped Master Cylinder Reservoir 76B MG 0
JFS Wedge Wedge Glove Box Triumph 6
tr7andtvr Wedge rear end ratio swap? TVR 1
DNK Wedge Wedge and TRF Carpet and others Triumph 9
ChrisS Wedge [no this doesn't belong in the 'rumph forum] Spridgets 5
DNK Wedge Wedge Cover emblem Triumph 3
T Wedge Wedge Completes 24 Hours of Lemons Triumph 1
philman Wedge wedge rear suspension Triumph 8
jclay Wedge Wedge Technical Site Triumph 5
T Wedge Latest wedge has landed. Triumph 10
Mickey Richaud Wedge Nice Wedge on Ebay Triumph 22
PATR8 Wedge Wedge Seats Triumph 5
T Wedge Progress and a Wedge question Triumph 5
