My sons beemer has two vacuum lines to the distributor, one is connected under the choke unit on the Weber DGV. The other is missing. Where should it connect?
Is it a Bosch dizzy?? The port on the back side of the
vacuum can should hook to a manifold source, the front
side should hook to the port near the idle enrichment
screw...
