lbc_newbie
M1chael said:I'm not sure what type of exhaust or intake manifold that you are running, but, I have the stock exhaust with the Pierce intake and they have a different thickness at the flange. I had to manufacture a washer/spacer that was different heights to make sure I did not have any leaks. No idea if that is your problem, just throwing it out there. If you pull it off, replace you brass nuts. Mine were 8mmx1.00.
Mike
You are spot-on, Mike. I noticed that prior to the engine rebuild. Before I replaced the SUs, I ground down the Pierce manifold flanges to get them flush with the stock exhaust. This should not be the problem, but an excellent point. It was something that had always bothered me!
