EEtinkerer
OK Everyone,
I'm back and this time with no more good news as to the running state of my TR6 with the triple 40DCOE webers. I took the jets out last night and blew them all out with the compressor to make sure they were not blocked. I also took the needle valves out and blew out the seat with air as well as the little filters above. Putting my mouth to the fuel inlet, I tested the needle valve and it indeed closes and opens with the floats. The engine still runs poorly after changing all the basic ignition parts (points condenser cap etc) and rechecking base timing with a test light as suggested in some old triumph books.
I have another question about a problem that seems like it could be causing many of my headaches. All three of the carbs (all six barrels that is) pour raw gas directly out into the air cleaner assembly. I took the air cleaner off to look while I tune and the gas just rolls out the fronts of the carbs and onto the fender. This seems very strange. i have checked and adjusted the needle valves on all the carbs and no adjustment level seems to stop this problem. I've checked the alignment of all the throttle plates across the carbs to make sure they are all in alignment and they seem to be all zero-ed plus 1/2 turn on the throttle screw. All idle mixture screws are set to 3/4 turn. I tried as some suggested with new gas and the car still doesnt run so I think that this spillage problem is a cause (it's at least not a desirable or SAFE thing to have.) Any of you with weber knowledge would be greatly appreciated! Thanks again!! One last question about the running problems. The rough running seems to disappear when the engine reaches 3000rpms which seems to be the limit of the idle circuit so it sounds like there is a problem in the idle/progression circuit. If that information helps diagnose the gas spillage OR the running problem, I will be most grateful!
A.J.
A.J.
