Weber Carburator rebuilding DCOE
hondo402000
Well since I have my wiring finished, its back to the carburators, I couldnt figure out why I have a miss at 3000 rpm so I figuerd maybe they need to be cleaned on the inside and also when I let up on the accelerator I was always pertrubed that the idle wouldnt come down unless I blipped the throttle, So off with the webers. I attached several pics, one showing the carb top open. one of the acc pump jet plunger and one looking down the throat of the carb., Seeing how the webers are 5 years old. DCOE do have a pre filter and there was trash in them( thats probably because it was before I cleaned my gas tank) I did find some trash in the bowls and a little water. So cleaned them all out. The one thing that I could never figure out was why the butterflys would hang up. Well now I know why. the accelerator pump jet has a small brass plunger that is actuated by the throttle shaft and the plunger likes to get hung up on its return to normal position. So I took them out and buffed them to a mirrow finish, but as always one shot across the shop but I found it and no damage I was lucky there. Next if you look at the one pic you notice that when the butterflys are closed there is Light, I dont think god said when butterfly is Closed LET THERE BE LIGHT, just shows you how cheap things are made. they all have some issue but I guess thats why they have Idle screws and why some are open more than others.
poolboy
hondo402000 said:
carb throat and how the butterfly not a good fit
That's not the way it's supposed to look when the engine is at idle ?
hondo402000
hondo402000
sorry the carbs are off the car, and yes the butterflys should fit better but I didnt make them just have to deal with them
Hondo
poolboy
Hondo, that was a question, not a statement.
Seems to me that the throttle disc has to be slightly cracked open if the engine is expected to idle.
I was asking if that was the situation pictured. I realized that the carbs were not on the car but was the carb adjustment still set in the idle position ?
hondo402000
hondo402000
sorry! yep the idle screw was backed out all the way. On Webers DCOE carbs their is an idle circuit and it pulls air air and fuel thru the that circuit and bypasses the butterfly valves. I dont have my book in front of me its in the shop so I cannot be 100 percent sure but they should close better than that
Hondo
Platinum
With the idle set screws all the way out, the throttle blades should be sealed to the I.D. of the barrel.
Only the choke circuit bypasses the throttle blades, idle draws air from past the throttle blades.
With that blade misalignment, look at the SHAFT carefully to insure it hasn't been twisted from someone overtorqueing the shaft retaining nut(s).
The choke "barrel" seats can be crudded up and allow air past them, too. That can cause odd issues.
hondo402000
hondo402000
well since I purchased them new from pierce manifold, shaft retainer nuts on the sides have never been touched, So not sure what my options are for fixing them, and its next to impossible to get the screws out to remove the butterflies
Hondo
hondo402000
hondo402000
I thought about calling them today but then I bought them 5 years ago so most likely they wont do anything about it now. I did find out one thing, I checked the float heights, ALL WRONG the book says 15 mm which is .590 inch just one more issue thats made it difficult to tune them, So in closing, even when you purchase brand carburators off the shelf, you best check everything to make sure its set right!
here are the measurements I took this morning
one .557 inch = 14.7 mm
one .503 inch = 12.7 mm
one .450 inch = 11.3 mm
Hondo
DNK
5 years, ouch.
Know your pain. Remember the exhaust I bought from Moss 11 years ago.
They replaced the problem 11 years later.
You can ask,I guess.At least if you need parts they might help you out
hondo402000
hondo402000
I talked to the tech guy at pierce, he said a little light is ok, but he also told me the float setting should be 12.5 MM for the plastic foat, 15mm for brass they were still off, So back to the shop, and reset again.
UUUUUGGGG
Hondo
hondo402000
hondo402000
Well done and its running much better, now my spedo isnt working, must have pulled the cable out at the tranny when I took the spedo out, because the cable does not turn while driving just another thing to fix
Hondo
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
W Weber/stromberg air cleaners Jaguar 3
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
B Weber DGV Spridgets 2
TomChar Weber MCHH carbs Triumph 23
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
Pythias Weber DGAV questions Spridgets 8
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
