As best I can tell (still no garage lights) the heater hose is on the left side because that is where the radiator hose lives and also to keep it away from the distributor.
Final question (I think). The heater hose that used to run along the valve cover has a t-fitting in it that is currently blocked off - does this connect to the small riser right behind the valve cover (also currently blocked)?
