Gentlemen:
I posted recently about bleeding the clutch on a 1960 BE with a dual MC. Today my son and I tried bleeding the system but had no success. Let me explain what we did do:
- We detached the slave from the tranny. We pushed in the plunger while the bleeder was open. With the plunger down, we then tightened the bleeder and released the plunger. My son said the plunger would stay in place, back in the slave. Then I would pump the pedal with the bleeder closed. My son said this was not forcing the plunger out. He would only open the bleeder screw once I got the pedal to the floor. No of this seemed to generate any pressure on the system. At one point, when my son held the plunger in with his finger, we were able to feel some pressure on the foot pedal, but once he let go we were just going back down to the floor.
- We got a EZBleed type kit from the auto parts store. This had a hand pump. we attached a short tube to the bleeder screw, the tube then attached to a reservoir, and then a long tube attached to the pump. The pump could be set to vacuum. When we performed this operation we were able to draw fluid out of the hydraulic system and into the reservoir, but we never seemed to get a strong vacuum. We were also unable to get any pressure built up in the system.
- We had a spare MC cap. We drilled a hole in that, inserted a tube, attached the tube to an air pump, put the cap in the MC (which was filled with brake fluid), and tried to force enough pressure through the top in order to force all the air out. The cap was not airtight, and this approach did not do much of anything.
We are frustrated. We are considering disconnecting the slave and trying to fill it with DOT5 and then reattaching it to the system, in hopes of priming the slave.
I've read the other threads (that what we were working off today), but ANY help will be appreciated.
Mike Pennell
Mike Pennell
Hi Guest!
