Watson Mechanical Brake Light Switch
AUSMHLY
Heads up to all those who installed the Watson mechanical brake light switch. It will wear out and stop working.
I opened the unit up to find out why it wasn't working.
There are two brass electrical plugs on the outside of the unit. Inside of the case those plugs are flush with the surface of the black plastic plate.
The lever arm moves a brass contact with two protruding points till they come in contact with the two flush brass plugs ends. Over time the siding plate makes a grove in both the plastic and the brass plug ends.
Once it's worn, sometimes it makes full contact sometime it gets hung up and doesn't. No contact, no brake lights.
I filed the grove out of the plastic and the two brass contacts. Now it works like new. However because of the design, it will eventually wear out again.
I'm going to change the Watson light switch out to a metal door jam pin style. Those don't wear out.
Photos of each below.
Watson is with the arm. Door pin is straight
View attachment 36970View attachment 36971
I've been using this one as a mechanical brake light switch since 2006:
https://www.allelectronics.com/make.../15a-snap-action-switch-w/roller-lever/1.html
Comments -
Could one put a capacitor across the switch to prevent arcing as that's probably what erodes the contacts?
Using the switch to fire a relay would also likely make the points last longer.
If we opened the doors as often as we put on the brakes, maybe the door switch would wear out faster than the brake light switch.
Comments -
The problem with the watson is physical wear. It grinds a grove in the plastic and brass. Then it starts hanging up and not moving freely.
I wonder if the door pin switch will arc and wear out. Good point. What do others think?
Which switch are you referenceing in reguards to using a capacitor?
Are you using a capacitor or relay with your switch?
Steve your switch looks like a good solution. Could you post some photos of where and how you mounted it?
Thank you for providing the purchase link.
Years ago a Corvair club magazine article showed how to put a capacitor across the points on the electric clock to prevent arcing and quick-erosion of the points.
Would guess the capacitor used on the fuel pumps would be the same. This would work on any switch.
I'm not currently using either a capacitor or relay with this switch as I haven't had a problem yet.
Not sure how a capacitor or relay would interact with the flasher relay. Maybe no problem if the relay were close to the brake switch - the answer here may have to be developed through experimentation.
Brake switch is mounted on an adjustable bracket on the leading edge flange of the heater plenum such that the arm roller interacts with the rear of the brake clevis. See:
https://www.pbase.com/stevegerow/image/70570849
and preceding couple of images.
Well as Ausmhly pointed out his switch failure was due to a mechanical faiure of the switch components.
Adding a Capacitor across this type circuit will not add much to the circuits reliability as its characteristic is more on the resistive side.
Similarly, Relay switching is more often relegated to high current or inductive circuits switched by low curent devices-hand operated switches- and are not generally required in this type circuit either,
And why was the original hydraulic switch deleted? My BN6 is still energizing its brake lights with a something '58 date-coded switch, and problem-free.
If you don't trust the hydraulic pressure switch, rather than delete it, you could wire your mechanical do-dad in parallel with it (either/or would complete the circuit). By the characteristic of their response times, the mechanical switch would close first, and break (or open) first, thereby halving the potential for arc degradation__in theory! In reality, the current draw from those low wattage bulbs is a non-issue.
I did however, add a second hydraulic pressure switch (same OEM design) @ the rear axle, by substituting a 4-way** connector, to activate a 3rd l.e.d. brake light that's incorporated into my billet aluminum license plate frame. Power for the circuit was provided via the switched 12VDC+ from the nearby fuel pump. The benefit of a redundant circuit being one thing, but the truth is, I didn't want to confuse the combined brake light/turn signal function relay!
** it's actually a 5-way, with one (1) port plugged; happened to be something I had on hand.
I went with the mechanical switch when my original started leaking because: 1) bad reputation of replacements, 2) instant action of pedal switch and 3) theoretical improved reliability of having connections in dry location above pedals.
attachment.php
Yes as you can see. In this case the Inductance of the relay coil changes the circuit from a predominantly Resistive type to an inductive type and an inductive transient will occur and needs to be suppressed.
However, Normally the current draw from those low wattage bulbs is a non-issue.--Thank you RANDY
attachment.php
OK, so if I understand correctly, a capacitor wouldn't be necessary because the bulbs heat up slowly (in electronic terms) and so wouldn't cause a spark to jump across the switch points anyway. The author was using the relay 10 years ago because the pressure switches available were too light-duty and couldn't hold up to the bulbs' 3 amps for any length of time. Not sure why the relay by itself wouldn't be sufficient.
He doesn't explain exactly what the diode was for.
So maybe the switch quality has been rectified in the meantime and the new ones will last for an acceptable length of time.
If not, there's still an argument for the pedal-switch alternative.
The addition of the diode tends to reduce the amplitude of the inductive transient produced by the relay coil.
However, most of the time the diode is not used in low voltage circuits.
You're a lucky guy Randy, 1958 brake switch still working.
For the rest of us, when our original brake switch stop working, we replace them with what's offered, aftermarket repros.
Reproduction parts aren't usually made as well as original, so they seem to fail even quicker. Don't get me started. I went through 2 reproduction switches. When it was time for the 3rd switch, I read on this forum that another option was the mechanical (do-dad) ones. The Watson worked great for years, then the other day, someone told me, you know your brake lights aren't working. What!? So I opened the switch to find out why and wanted to give a heads up to those who also have this switch.
Sorry to resurrect an older thread, but here goes:
The quite-possibly-original brake light switch on my '67 BJ8 has quit. I've ordered a Intermotor replacement, but having read several posts on the subject I'm not confident of its longevity. After reading Steve's great posts (and pics) of his snap-action switch mod, I've ordered one of those as well, just to hedge my bets.
Then I came across the relay mod idea. I always thought relays were for higher draw items, but I'm game if it's a good idea. My question is whether the consensus these days is that it's better to go mechanical, or roll the dice with the aftermarket replacement for the OEM?
Thanks!
I am on my 2nd Watson's. The first one lasted about a dozen years. It was replaced with another in 2020. The original hydraulic was kept in place and reconnected until a replacement arrived. Problem is detecting a brake light failure in time to avoid a situation.
Mine fortunately failed in the "on" position and was discovered quickly. I've gotten in the habit of "pre flight inspections" before most drives.
WD 67 BJ8
