Hi Guest!
How about coolant from the hose between the head and the pump. That can look like water pump as well.
There is a little weep hole on the bottom of the extension for the water pump bearings where the pump leaks usually appear first. Usually not till the bearings get really loose. If you suspect your water pump grab hold of your fan and see how much movement there is in the bearings. Should be negligible.
Kurt
DSC_0008 by onyxsax, on Flickr
